Hello. I'm an IT guy and one of our users put in a ticket with screen shots showing an error message they get every single day when they sign on to their Windows XP computer. The first error message says:
FlashPlayerUpdateService.exe - Application Error
The instruction at "0x7c9113c0" referenced memory at "0x00050005". The memory could not be "written". Click OK to terminate the program.
The user clicks OK and then this comes up.
"Adobe Flash Player Update Service 11.3 r300 encountered a problem and needed to close." It then has the date and time of the error (which is when she logged into the PC) and a Send / Don't Send error report button, which we know are just placebos because sending these reports don't fix the problem.
What do you think is causing this? I wanted to report the error not only to get help on it but to make the product better so future versions can be written to not have these errors.
Test builds have been distributed. We believe we are on to a solid lead and fully expect that the next version of Flash Player will no longer have this bug. Until this release is available, please see this post for details on working around this problem.
Chris
And dont forget to vote!
According to this post, if you think this problem is worthy of Adobe's attention you should vote for it to be fixed.
I mean, unless the election is over.
Is the election over? Did this error win its way onto the Adobe support to-do list?
I am also seeing an error every day, but not during logon. Below are the various error messages I received over the past few days:
Today:
An unhandled win32 exception occurred in FlashPlayerUpdateService.exe [8120].
Last night:
An unhandled win32 exception occurred in FlashPlayerUpdateService.exe [6312].
An unhandled win32 exception occurred in FlashPlayerUpdateService.exe [5868].
An unhandled win32 exception occurred in FlashPlayerUpdateService.exe [4276].
Yesterday:
An unhandled win32 exception occurred in FlashPlayerUpdateService.exe [5640].
Sunday:
An unhandled win32 exception occurred in FlashPlayerUpdateService.exe [5248].
Products:
Adobe Flash Player 11 ActiveX Version=11.2.202.235
Adobe Flash Player 11 Plugin Version=11.3.300.262
Windows XP SP3
For those that are just looking for a temporary workaround, please follow these steps.
1. Open the Flash Player (32-bit) control panel in your Windows control panels
2. Select the Advanced tab
3. Windows Vista and Windows 7 users only, click the “Change Update Settings” button and select yes to the Windows confirmation prompt
4. Select “Notify me to install updates”
5. Close the control panel
If you continue to crash, the following steps will manually disable the update service.
Windows Vista and Windows 7:
cmd /c sc config "AdobeFlashPlayerUpdateSvc" start= disabled
Windows XP:
Once complete, you should see the output:
[SC] ChangeServiceConfig SUCCESS
You can now close the cmd window. The FlashPlayerUpdateService is now disabled. Please let me know if the error occurs again.
If you've changed your Flash Player updates to "Notify me to install updates" you will get a notification within 7 days of a Flash Player update. On Windows, the notification window will appear after a system restart.
I will make sure to update our Flash Runtime Announcements posts with details as soon as we've resolved these crashers.
Chris
Please see my post 3 responses up for a temporary workaround until we can figure out and solve this bug.
Chris, this new version seemed to work fine for a few days now the user put in another ticket today. This is the error message:
The instruction at "0x7c9113c0" refrenced memory at "0x00050005". The memory could not be "written". Click on OK to terminate the program.
When you click OK then you get Adobe Flash Player Update Service 11.3 r300 encountered a problem and needed to close. This error occured on 7/10/2012 at 9:44:00 PM.
However this user recieved this error when the signed on at 8:15 AM. The computer wasn't even signed on at 9:44 PM. Isn't that strange?
It's a 32 bit Windows XP machine, Service Pack 3, Office 2010 and 4GB RAM.
I'm going to have no choice but to disable the update service.
Thank you to everyone that has volunteered to help us debug this problem. We believe we are on to a solid lead and fully expect that the next version of Flash Player will no longer exhibit this bug. Until this release is available, please see this post for details on working around this problem.
Chris
Origiin Micro - I would recommend turning it on and seeing if your crash was fixed with 11.3.300.265. If so, great. If it still occurs, just toggle it off for the time being.
Chris
Chris,
I use XP Pro, SP3, IE8 and when you go to Control Panel, then click on Flash Player, then select Advanced Tab, there are bullets, one of which is the, "Notify me to install updates."
Via your suggestion from post: 7/12 in response to poster: Origin Micro: your instructions are incorrect:
-there is NO "change update settings" and,
-there is NO "windows confirmation."
So you are not talking about XP.
Then you say, "close Control Panel." Now what? Everything is still the same.
I don't know about anyone else here, but I am getting the Flash player 11.3 r300 error message saying it has to close and I am not even on the net. It pops up on my desktop.
And I just spoke with an IT guy who said that the latest flash player update was geared for IE9 yet I see numerous cases where this OS is equally affected.
All of this because I updated via a prompt from adobe and the update was from adobe, no third-parties. Additionally, the update did not and will not include the
plug-in. Yet once the download is complete, adobe takes me to a window saying the download was succesful. And even plays the confirmation flash screen.
Then I go to add/ remove programs and flash player is on the list, yet there is no corresponding file size and the plug-in is not even on the list.
@brianchaffee - What problem are you running into? Is it the FlashPlayerUpdateService.exe crash? Regardless, you are correct. XP is slightly different. In this case, go to the Advanced tab and simply click the "Notify me to install updates" option under the Updates section, then close the control panel.
@Chris Campbell - Chris, every site I visit tells me the same thing: You need flash player to view this video. [Also, please refer to my original post where I dilineate all that is a problem on this end.]
QUESTION:
- how is it that I go to Adobe, click on and download latest flash player, then I am taken to another page where the flash mini-movie and worded confirmation that I now have the latest flash player and yet when looking in: Control Panel > click on Flash Player, it says ActiveX Player Installed/ Plug-In NOT Installed: Why doesn't the Plug-In install?
- even not logged onto the net, the 11.3 300r message pops up on desktop saying the flash player has to close, sorry for the inconvenience, etc., why?
We are all getting the same errors for the most part and dealing with the same problem.
I really appreciate you staying around here Chris, but it seems obvious you [and Adobe] do not know what the problem is. This is not to be unkind but citing a trueism. We are all unable to access flash oriented video one way or another. That is the problem.
So I do not understand your question you asked me above which was: "What exactly is the problem you are experiencing?" Answer: We downloaded your latest player and now it does not work at all. THAT is the problem. Across all browsers regardless. All this while html5 comes roaring up from behind.
What does Shantanu Narayen, Adobe's CEO have to say about this? How about your IT department?
@KJSTech: " I foget where the debug stuff goes or I'd try to send you something. I can't find that post."
Is this it?
http://helpx.adobe.com/flash-player/kb/report-flash-player-crash.html
