dingiso
Opera and the latest Flash Player
Jun 28, 2012 2:44 AM
I posted the question below in the installing player forum and unfortunately I have had no replies. However there is an additional problem in that I can not acess images on the Ancestry website. It is asking me to install the latest version of flash (which I believe I have see below) it is starting to get really frustrating having to switch to a diferent browser every time I want to view images. Does anyone know if Abode are even trying to fix the problem with opera?
I am using Opera v 12 build 1467 as my browser  and my OS is windows XP SP3. I have been trying to watch content from BBCi player and a message appears telling me to update my Adobe Flash Player. I have followed the instructions on the Adobe website but still get the same message. I have verified (via the control panel) that the laterst version is installed ( 11.3.300.262) but still get the same message.  If I go to the adobe flash player help page there is no image in the box and no matter how many times I've tried to uninstall and then reinstall the flash paler the results are still the same. I have also checked Opera Plugins to see if it disabled but there is no entry for the flash player although shockwave & acrobat are there.
It appears to work fine in Firefox ( v. 13.0.1).
Is there something else I need to do or does the flash player simply not work in Opera?
I wouild really like to continue using Opera as it works well with few clitches.
Any help or suggestions would be greatly appreciated but please keep it as simple as possible as I am not very good with code or registry editing.
Many thanks,
Dingiso
    Jun 28, 2012 6:21 PM   in reply to dingiso
    The best way to move this forward would be to file a bug: http://bugbase.adobe.com/
    Please provide as much information as possible on the issue you're observing, your configuration and steps to reproduce.
    Jul 5, 2012 2:32 AM   in reply to dingiso
    I think the problem lies with Opera 12.  Just look at http://my.opera.com/community/forums/topic.dml?id=1434662   I'm struggling with Opera 12 and Flash Player.
    Jul 10, 2012 3:57 PM   in reply to dingiso
    I'm in the US and am not allowed to watch BBC iPlayer content, so I can't check to see if I might have the same issue. I have had the same problem with other sites, though, and it was caused by problematic coding within the website. The workaround: 1) Right-click on the page whose Flash content won't play. 2) Select "Edit Site Preferences..." 3) Click on the "Network" tab. 4) In the drop-down menu for "Browser Identification," select "Mask as Firefox." 5) Click "OK." 6) Reload the page.
    Hope that works for you.
    Dec 8, 2012 5:14 PM   in reply to AisuruMirai
    WOW!!!  That was so easy...and it worked perfectly! (I had masked it as IE which didn't work.) Thanks AisuruMirai
    Jan 24, 2013 2:13 AM   in reply to dingiso
    Hi there! I had the same problem and what I did is that when I went to the site where the plugins do not work, I right clicke the page and chose Edit Site Preferences. Then clicked the Content Tab and put a check mark on the Enable plugins! I hope I have helped you
Bookmarked By (1)
