I am upgrading from Acrobat X Standard to Acrobat X Pro. When trying to install Acrobat X Pro I get this mesasge - "Setup has determined that you already have a more functional product installed. Setup will now terminate." And it does terminate! What would be my problem? The only other Adobe programs I have installed are - Adobe Air; Adobe Flash Player 11 Active X; Adobe Flash Player 11 Plugin
Yes you should. Although if you don't have an option to uninstall in Add & Remove Programs that is going to make it much more difficult. You can try using the Acrobat Cleaner tool however located at http://labs.adobe.com/downloads/acrobatcleaner.html.
Do you use a registry cleaner or any other type of system optimization utility btw?
