JQuery Cycle issue with IE9
Jul 5, 2012 4:14 PM
Tags: #jquery #cycle #jquery_cycle
I'm in the process of reworking an old website and wanting to insert a JQuery Cycle slide show from the CS6 DW widget browser.  The slide show looks beautiful on all browsers except, you guessed it, Internet Explorer.
Here's the deal, when loaded on IE9 the images overlap the text in the adjacent div.  I have the same issue on another site whereby the images drop over the div located below.  Again, this only happens on IE9, all other browsers work beautifully.  Yes, adding padding to the widget div is a temp fix, but then creates a new issue by adding too much blank space on all the agreeable browsers.
Suggestions?
Many thanks.
Here's the site: http://www.thethinman1934.com/thethinman.html
    Jul 5, 2012 4:22 PM   in reply to Chris Wessling
    If that temp fix helps, then you can apply it to IE9 only via an IE Conditional Comment.
