Computer build
Jul 5, 2012 1:26 AM
Building a computer tailored for CS6. Here is what I am looking at and wanted to get some feedback on it.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber =19718092
Thanks.
  • PECourtejoie
    Jan 11, 2006
    Jul 5, 2012 2:57 AM   in reply to lvvwvert
    Hello!
    I'm amazed at the computing power one can get nowadays with 1 grand.
    My only suggestion, if you can afford it, would be to have more RAM. (there is never enough)
    the machine does seem to fit well within the recommended hardware list, http://blogs.adobe.com/jnack/files/2012/07/CS6_hardware_recommendation s.pdf besides the videocard, but I don't know anymore how a 550 differs from a 570...
  • Noel Carboni
    Dec 23, 2006
    Jul 5, 2012 6:50 AM   in reply to lvvwvert
    I wouldn't mess with the additional complexity of caching SSD.  Save just a little longer and get a big high-end SSD (e.g., OCZ Vertex 4 240GB or even 480GB).
    Also, echoing what Pierre has said:  16 GB RAM is a must, 32 GB or more is preferable.
    -Noel
    Jul 5, 2012 9:57 AM   in reply to lvvwvert
    You might also want to go to the Adobe Premiere Hardware Forum, and have a look at some of the threads. Though most of what is being talked about there is hardware to run Premiere Pro (has some similar requirements to PS, but more of them, and at a higher intensity level).
    There are several very active SSD and also RAID discussions there now, and there might be good info for you.
    Good luck,
    Hunt
    PS - pay special attention to the comments and threads by Harm Millaard, and also ECBowen, from ADK Computers.
  • Trevor.Dennis
    May 24, 2010
    Jul 5, 2012 3:34 PM   in reply to Noel Carboni
    -Noel
    I'll add a 'me too' to both statements.  The SSD market is ever changing, and you really need to do your research before spending your dollars.  Tom's hardware did a 'best for the money' group test in June, so that's a good place to start.
    http://www.tomshardware.com/reviews/ssd-benchmark-review,3237.html
    Jul 5, 2012 11:34 PM   in reply to lvvwvert
    CUDA won't do a thing for Photoshop -- Photoshop does not use CUDA.
    It will help Premiere and After Effects, though.
    And how much RAM you need depends on your specific work habits (document size, documents open, other apps open, etc.).
  • Noel Carboni
    Dec 23, 2006
    Jul 6, 2012 6:27 AM   in reply to lvvwvert
    At first it looks like you have a budget build in mind, then you talk about 64 GB RAM, which could itself be more expensive than the entire system you noted, above.
    Perhaps the pertinent question is this:  What's your budget?
    If you have a few thousand dollars to spend you could build a SIGNIFICANTLY better workstation than for one thousand dollars.
    If you have ten thousand dollars to spend I doubt you could get a more powerful system on the planet than one of the new Dell Precision T5600 workstations.
    My point is that everyone has a target price in mind, and for any given price you can only build so much system, which in turn will be useful for a certain amount of time before it becomes obsolete.
    -Noel
