greenrookie
change filename using GREP
Jul 5, 2012 12:36 PM
Hello,
I'm trying to get these lines of code to change the filename when saving;
to: HAlcatraz
if(myDocName.indexOf("z")!=-1){
var myRegularExpression = /\\<z/gi
myDocName = myDocName.replace(myRegularExpression, "H");
I'm trying to target just the first z at the front of every filename but can't get the grep correct.
Any thoughts?
Thanks in advance,
GR
    Jul 5, 2012 9:23 PM   in reply to greenrookie
        Use the below codes...
    myDocument = app.activeDocument;
    path = myDocument.fullName;
    var x = path.toString().replace("z", "H");
    myDocument.save(File(x));
    Hope this will help you...
    Thanks and Regards,
    Vel.
    Jul 6, 2012 1:25 AM   in reply to greenrookie
    Vel's code will replace all instances of lowercase 'z' with uppercase 'H' -- even the ones in the file path.
    Better try this:
    myDocName = app.activeDocument.fullName.path+'/'+app.activeDocument.fullName.name .replace(/^z/i, "H");
    (The GREP code you were probably looking for is '^' -- start of 'line', in this case equal to the start of the string.)
