piedpiedpiedpiper
Disable Black Point Compensation
Jul 4, 2012 1:15 PM
Hi, now I am struggling against disabling Black Point Compensation when I view an image normaly (not with "Proof Colors").
In my understanding, we can turn off BPC with "Color Settings" daialog.
But in fact,  RGB(0,0,0) image shows the lighter color as device-RGB (I checked it with a color picker application). That means BPC ON.
Does anyone know how to turn off BPC?
The folllowing is my environment:
OS: Windows 7
Ver.: Photoshop CS6
Conversion Options: ACE, Colorimetric
My goal is viewing an image in Photoshop as same as the other application, using
LUT based ICC profile as monitor profile. I think it needs disabling BPC.
    Jul 4, 2012 1:52 PM   in reply to piedpiedpiedpiper
    For image display, BPC will remain on (as it should be).
    If RGB)0,0,0) shows up as something other than 0,0,0 - that means that BPC is off, and the profile has a problem.
    BPC maps black to black, to correct problems with profiles that don't always map the darkest color correctly.
    BPC off really only applies for print conversions (some of which you can simulate in proof settings).
    Jul 4, 2012 2:00 PM   in reply to piedpiedpiedpiper
    Unchecking the BPC in the Color Settings dialog turns off BPC for mode changes and color transforms...it doesn't have anything to do with how Photoshop displays your image and you can't control how Ps displays the image on screen other than soft proofing aside for the creation of the display profile and the display calibration. Not sure what "color picker application" you are referring to but if your display is showing 0, 0, 0 RGB as being lighter than max display black, something is wrong with the display calibration and profile.
    Edit, plus what Crhsi says :~)
    Jul 5, 2012 3:45 PM   in reply to piedpiedpiedpiper
    That monitor profile does have several problems (Version 2 profile whose whitepoint isn't D50, black input does not give black output, tables don't appear to be inverses, etc.).
    Jul 6, 2012 5:11 AM   in reply to Chris Cox
    This monitor profile cannot be interpreted by Gretag-Macbeth Profilemaker.
    Profile connection space is Lab. Normally one would use XYZ.
    IMO there is no BPC for conversions between RGB working spaces and
    monitor profiles. Working space black R=G=B=0 is mapped to monitor
    values R=G=B=0 and appears with the darkest available monitor luminance.
    Further discussions are here, including Adobe's BPC and Argyll comments:
    http://www.google.de/search?hl=de&as_q=&as_epq=Adobe+BPC&as_oq=&as_eq= &as_nlo=&as_nhi=&lr=&cr=&as_qdr=all&as_sitesearch=&as_occt=any&safe=im ages&as_filetype=&as_rights=
    Best regards --Gernot Hoffmann
    Correction
    Sorry, my mistake! I didn't check the box in front of the profile name
    (which is normally not necessary, starting with one profile).
    This gamut volume in Lab looks now quite normal.
    Especially it reaches down to L*=0
    Message was edited by: Gernot Hoffmann
    Jul 6, 2012 12:21 PM   in reply to Gernot Hoffmann
    It's a table based profile, so LAB is just fine.
    Also, check both tables for the profile - it doesn't always map to zero.
