Dennis Ganz
Can missing (deleted) photos be restored from previews?
Jul 6, 2012 11:12 AM
Hi - the original files are gone, deleted accidentally.
But my LR3 catalog still has full size previews of all of them.
Is there any way to convert those previews into photo files (dng or jpg would be fine)?
It seems like this should be possible - I can see the images right there on my screen, so they can't be gone for good!
The deleted photos comprise an entire day in Venice, Italy, and had already been sorted into keepers.
Even if I could only get a medium sized jpeg, it'd be better than nothing at all.
Hope someone can help!
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 11:14 AM   in reply to Dennis Ganz
    http://helpx.adobe.com/lightroom/kb/extract-previews-lightroom-4.html
    As you see, you can get previews which depending on the preferences set are differing sizes.
    Jul 6, 2012 11:50 AM   in reply to Dennis Ganz
    Only use the Adobe script if you don't mind the colors being off (proper ICC profile is not assigned).
    This will recover previews and assign the correct ICC Profile:
    http://www.robcole.com/Rob/ProductsAndServices/PreviewExporterLrPlugin
    Rob
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 12:26 PM   in reply to Rob Cole
    The color isn’t off, it isn’t defined because these are untagged aRGB documents. And if a user had, say aRGB set as the RGB working space in Photoshop or using any application that assumes untagged data is aRGB then everything would be OK as the assumption is correct.
    Jul 6, 2012 12:22 PM   in reply to Dennis Ganz
    Dennis, most but not all previews are AdobeRGB, but they will be interpreted as sRGB after extraction, if no ICC profile is assigned, so not way off, just a little off.
    Still, even vacation photos should look good, no?
    Anyway, ImageMagick is a pain to install on Mac, but exiftool is a piece of cake. If I were you, on a Mac, I'd try PreviewExporter after installing exiftool. It will at least provide a more informative error message even if it fails.
    Dennis Ganz wrote:
    I notice some of the images momentarily display the "!" with the 3 lines next to it before the symbol changes to the missing file symbol.
    Is that relevent?
    Dunno. maybe sombody with more knowledge will say. I can imagine this being normal or indicative of database inconsistency.
    R
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 12:26 PM   in reply to Dennis Ganz
    Is that relevent?
    It sounds like the previews missing were never fully built....
    Dennis Ganz wrote:
    Rob, I don't mind if the color profile is wrong, so long as the colors aren't way off - these are just vacation photos, nothing professional.
    Just assign Adobe RGB in Photoshop and you’re set.
    If you are on a Mac, you can use Automator to do this as well if you don’t have Photoshop.
    Jul 6, 2012 12:26 PM   in reply to Andrew Rodney
    Andrew Rodney wrote:
    The color isn’t off, it isn’t defined because these are untagged sRGB documents.
    Most documents are AdobeRGB, and need the profile assigned to be displayed correctly. This is not only my understanding, but my first-hand experience.
    Jul 6, 2012 12:31 PM   in reply to Andrew Rodney
    He said he can see them, so they are built.
    This will be the right thing to do in some cases, and the wrong thing to do in other cases. The trick is figuring out whether it's right or wrong...
    PreviewExporter has the requisite logic built in, but you can also use an SQLite3 client to find the requisite info in the database, if you know how.
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 12:29 PM   in reply to Rob Cole
    The assumption from LR that all untagged data is sRGB is going to bite Adobe and end users in the butt eventually. Today, it isn’t a bad assumption, tomorrow, when far more people will be dealing with wide gamut displays that produce something far closer to aRGB than sRGB, it is going to be a problem. At some point, we’re going to need a preference or just stop producing untagged data (a better solution).
    Jul 6, 2012 12:34 PM   in reply to Andrew Rodney
    Not sure what you are talking about. Lr handles it perfectly within (or at least that has been my experience), it's only the recovery script that short-changes.
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 12:33 PM   in reply to Rob Cole
    He said he’s seeing "!" with the 3 lines next to each which sounds like the necessary preview data isn’t all there. Don’t know. Unless the script is buggy, why did some previews make it?
    Dennis, do you see anything different in LR for the images that did successfully export?
    Yup, the issue with untagged RGB mystery meat. At least the OP can assign and compare to the previews or just pick a preferred rendering based on the assignment.
    It is really too bad the script can’t do something as simple as embed a 4k matrix profile that describes aRGB.
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 12:35 PM   in reply to Rob Cole
    Rob Cole wrote:
    Not sure what you are talking about. Lr handles it perfectly within, it's only the recovery script that short-changes.
    Agreed. It seems like something quite easy to do. And the web site should be more clear about what one should be doing with the untagged data.
    I believe the !-three-lines indicator designates a metadata problem which would correct because there is no metadata sidecar data (XMP file or image-embedded data) to compare the LR settings with—you’d get the same thing if you deleted a RAW file’s XMP file or restored a JPG back to the original without any Adobe-embedded data in it and had made LR adjustments previously., but in this case the error then changes to missing-image because that is even more of a problem.  I would think you’d see the metadata-problem indicator for any images that had non-default settings in LR, although perhaps there is a display-update delay and the one error is replaced by the other before the display is updated.
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 12:38 PM   in reply to ssprengel
    True and my bad, I was reading this and thinking about the dreaded ... (three dots) which I believe we see far too often as LR is updating or building a preview. IF that is what is seen, then makes sense why so many didn’t export.
    Jul 6, 2012 12:42 PM   in reply to Andrew Rodney
    the ! + 3 lines is a metadata icon - has nothing to do with preview availability. If you can view in lib module, the preview is there (the database may be wonky, but the preview is there).
    ...why did some previews make it?
    Dunno. I've had & fixed bugs in PreviewExporter too, and even so, 1 user complained about recovery errors that I was never able to solve. Shist happens...
    Previews are jpeg image data, no metadata. Database has the requisite metadata. They are not untagged, there is no mystery. You just have to have code to deal with the icc profile, and the Adobe script does not have such code.
    It was a quick n' dirty script. SDK does not have requisite support, so it either needs to be an app, or use external apps - adds considerably to the complexity, and probably would need to be a full-on plugin...
    R
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 12:51 PM   in reply to Rob Cole
    There’s no embedded ICC profile right? So they are untagged. Yes, it is also possible to define this using metadata (eg DCF) but not too many app’s recognize this, it just makes sense to embed a tiny 4K ICC profile into the JPEG. Totally doable no?
    You open said JPEGs in say Photoshop, with proper color settings, it is going to pop the missing profile warning right? So how can they not be untagged? Big mystery for anyone but the person who used the script received said data. And considering that the web site for download doesn’t mention that the data is in Adobe RGB (1998), which they should, seems pretty mysterious to me and I’m sure most people using the script.
    Don’t know anything about scripts and the like. I do know an AppleScript can do this and has been able for years.
    Jul 6, 2012 1:06 PM   in reply to Andrew Rodney
    If you use the Adobe script it will create untagged files, that is correct.
    I'm not aware of any lua script code that can assign an ICC profile, although it may exist somewhere... (such code would be of no value however, unless it was accompanied by the capability to access an SQLite database).
  • Andrew Rodney
    Apr 16, 2009
    Jul 6, 2012 1:10 PM   in reply to Rob Cole
    At the very least, Adobe should point to some resources that will embed the proper profile. Not easy in terms of simplicity and for free on both platforms. Easy on the Mac with either the supplied AppleScript or Automator Workflow. On Windows, Mac (and Linux), Little CMS which is free can do this.
    Of course anyone with Photoshop and presuably Elements can do it.
    I’m glad Adobe provided this script, but at the very least, they should maybe update the web page and let users know what to expect and not assume someone is going to automatically ingest the exported previews back into LR which makes the wrong assumption about the color space.
    As much as the team hates preferences, I see the day when we’ll need to pick aRGB instead of sRGB unless LR just pops a dialog when it encounters untagged data. Or maybe a badge telling us this is untagged. In fact a badge or some metadata we can search on or make a smart collection based on color space would be oh so nice. As you point out, the data (or lack thereof) is there already, we can’t we search on it and why can’t LR show us this somehow?
    Jul 9, 2012 2:56 PM   in reply to Dennis Ganz
    Dennis Ganz wrote:
    So, is my logical next step Rob's link in the 2nd reply?
    If you just used PreviewExporter in the begninning, you wouldn't be having these problems. (of course, you may be having different ones instead...).
    I'm not sure why you are intimidated by it. On Windows, it's plug n' play (install, then select photos, and click 'Recover Previews'). On Mac, you just need to install ExifTool (and/or ImageMagick) first, and point PreviewExporter to it/them. Then, it's same as Windows.
    PS - No points lost for asking a question in my book, if it's not playing after plug...
    Good luck,
    Rob
    Jul 9, 2012 6:20 PM   in reply to Dennis Ganz
    Dennis Ganz wrote:
    Sorry Rob, there's just a lot to read on that page, and many steps...
    No skin off my nose, but it does sound like you are going through way more trouble than you would have had to.
    PreviewExporter is first and foremost an export plugin. Preview recovery was an afterthought. But thanks for raising the flag...
    One day I may separated it into 2 and optimize the recovery for users only interested in that aspect.
    (or, I may not...)
    Cheers,
    Rob
    Jul 20, 2012 6:47 AM   in reply to Andrew Rodney
    I had problem with the extract preview script on the mac - when I run ExtractPreviews.lua from the script menu it brings up my editor instead of running it - I'm sure it's some sort of filetype/application association problem - does anyone know how to fix it?
