Aggregator for HTML5
Jul 6, 2012 12:43 PM
Is there a similar feature to aggregator in Captivate 6 that could aggregate HTML5 modules?
    Jul 9, 2012 4:45 AM   in reply to jay fresno
    Hello,
    Welcome to Adobe Forums.
    Aggregator only accepts .swf formats so if you are uploading your HTML5 modules on an LMS, then you can call the 2nd module at end of your 1st module.
    Note : When you upload your module on it gives you a direct link, you can use that direct link (or URL) on the last slide of your 1st module.
    Hope its helps !!
    Vikram
    Jul 10, 2012 2:22 AM   in reply to jay fresno
    Hello,
    As you mentioned that you are using IIS, so you will place the "Published" folder on the root location (C:\Inetpub\wwwroot\)
    To access 'module1', URL will be http://localhost/Published/module1/index.html (Depending on your server URL, localhost might get changed with your Server name)
    On the last slide you will Insert a hyperlink or Text Caption (Click box over it) and you will call URL : http://localhost/Published/module2/index.html
    You can test this and then follow the same steps for other module, users will able to navigate to other modules as well
    Note : Same steps will apply for Apache Server
    Hope this helps !!
    Vikram
