Set Poster Frame of Footage Item
Jul 5, 2012 1:12 PM
Tags: #footage #set_poster_frame
Hey,
I know how to set a poster frame for a comp (With comp selected, Composition>Set Poster Frame) but how does one set the poster frame for a footage item in the project panel? Obviously that option is grayed out as it is under the composition window. Is there any way to do this? Google has failed me. All my clips start with black video and I just want a way to quickly preview what their actual content is using the poster thumbnail.
    Jul 5, 2012 2:19 PM   in reply to DannyAskew
    My question would be - why do you want to do this? what are you trying to achieve?
    Remember... everything in the project panel is just footage - elements to be used in your final piece. I can't think of a reason you would need to set the poster frame for a video clip that is in the project panel.
    The piece does not become your final piece or working piece, until you have created it in the timeline. So once you drag elements to the timeline and edit them, add effects, etc. - then you can set the poster frame.
    Now, on the otherhand, if you are saying:
    - you have footage in you project panel
    - you have created a piece in your timeline that you want to set a poster frame for (ie, this will be the movie you want to render)
    - but you can't do so from the project panel
    this is how AE is designed. You have to have the panel active that you are using. So if I have my piece created in the timeline, I want to render it - but first add a poster frame, I need to make sure that I have selected the timeline panel before I can do so.
    Does this answer your questions? Let me know if I am not understanding you correctly.
    elaine
    motion.tv
    Jul 6, 2012 6:22 PM   in reply to DannyAskew
    Hi Danny,
    I understand what you are saying - and agree that this would be an excellent feature!
    The Premiere Pro team did a fantastic job of this in the new interface for CS6. Currently, I don't believe there is anyway to achieve the equivalent in After Effects. You can only set the poster frames for comps. I would recommend filing a feature request <https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform> to help make this happen.
    Personally, I would love to see many of the new user interface features in Premiere become a part of AE in the next release.
    elaine
    motion.tv
    Jul 6, 2012 6:44 PM   in reply to DannyAskew
    A workaround:  precomp all footage when you import, then create poster frames for the precomps and use them as your footage.  Not ideal, but a few mere clicks extra.
