geoffmeston
Is there a way that multiple people can work on the same folio
Jul 6, 2012 7:08 AM
Is there a way that multiple people can work on the same folio?
    Jul 6, 2012 8:12 AM   in reply to geoffmeston
    I would say yes.
    Different people can connect to a same folio through their own Folio Builder Panel to work in the same folio (if not a local folio).
    But they can't share articles, in my opinion.
  • Branislav Milic
    Jan 12, 2010
    Jul 7, 2012 5:22 AM   in reply to Christophe_Quinzoni
    Yes it is possible. Just set up the same software and configuration on two or three Mac/PCs and then put all the assets of a project on a local or remote server (I use DropBox so it is also available remotely).
    I use this technique to upload heavy folios containing dozens of articles.
    Mac 1 uploads articles from 1 to 30
    Mac 2 uploads articles from 31 to 70
    Mac 3 (which could be in an external location) uploads articles from 71 to 110
    All three use the same Adobe ID so everything goes in the same folio.
    Result: I divided the uploading time by 3.
    Remember: the Folio Builder panel is only a window that shows you what happens on the Folio Producer server at Adobe's. There is no folio stored locally on a machine unless you specified it.
  • Branislav Milic
    Jan 12, 2010
    Jul 7, 2012 5:25 AM   in reply to Branislav Milic
    When I write "Just set up the same software and configuration on two or three Mac/PCs" it means: be sure that you also load the fonts, the same Color Settings,... on all the machines. Open a few files just to check there is no warning box upon the opening of a document.
    Jul 7, 2012 5:25 AM   in reply to geoffmeston
    In addition, with everything in a shared folder, if someone who hadn't originally worked on a file needed to, you could use the relink feature to update the folio, in a pinch.
    Bob
    Jul 7, 2012 6:48 AM   in reply to geoffmeston
    I usually work with a friend on my folios. We work directly from a dropbox folder, and both of us have created a user with the same name on our macs. This gives us the same path to the folder, so we never need to relink when we work together from that user account. Works great.
    Jul 7, 2012 7:15 AM   in reply to eddie_dps
    Now that’s an excellent idea! I may have to steal that one.
    Bob
    Jul 7, 2012 10:39 AM   in reply to Branislav Milic
    As for fonts, I'd say: Stick to OpenType.
Bookmarked By (1)
