Paul Howson
Blog RSS feed not working. Why?
May 2, 2012 1:09 AM
I have a blog on a new BC website. It has been up and running for a few weeks. The RSS feed for the blog is not working. It just returns a web page saying: "ERROR: Either the RSS channel no longer exists or if this is a new channel then the feed file may not have yet been created. The feed file is created automatically at regular intervals. Please check again later.". The ID param for the blog feed url is the correct ID for the blog. I have other blogs on other BC sites where the RSS feed works correctly. Not sure how to troubleshoot this. Link to sample page is:
http://totaleducation.businesscatalyst.com/_blog/Richards_Blog/post/Ch allenging_the_Productivity_Paradigm/
    May 2, 2012 10:00 AM   in reply to Paul Howson
    Hi Paul!
    The issue I'm seeing here is that you do not have any RSS feeds within the site as this may have been deleted at some point.
    I get the following error when selecting the RSS feed on the page you've provided.
    So you'll need to go into your site and create a new RSS feed for your blogs.  Then add it to your blog layout to correct this issue.
    - http://screencast.com/t/T36WADJxH6
    KB reference: http://kb.worldsecuresystems.com/000/bc_9.html
    Kind regards,
    -Sidney
    May 2, 2012 5:15 PM   in reply to Paul Howson
    Very true Paul.  I had the very same issue and followed your example and it fixed it...  Definately buggy.
    May 4, 2012 11:45 PM   in reply to Paul Howson
    I still have the very same problem.  The rss channel is there and the blog has posts in it.
    I get the same error message as Paul above.
    Any reason for this and is there a fix?
    May 7, 2012 9:13 AM   in reply to Paul Howson
    Hi guys,
    Paul: The original RSS feed looks to have been removed.
    Old ID: 4839
    New ID: 8365
    The actual working one is below so you'll need to update the RSS feedlink to match this.
    - http://totaleducation.businesscatalyst.com/RSSRetrieve.aspx?ID=8365&Ty pe=RSS20
    Earthan: Can you provide the URL of the feed/page that is not working?
    Kind regards,
    -Sidney
    May 12, 2012 5:55 AM   in reply to Sidney Mitchell
    I have the exact same issue.   I have a blog.  The checkbox is checked to syndicate it.  The RSS feed is created, but there is nothing in it and I get the same error message.   I tried unchecking the syndication button and saving, then removing all RSS feeds and saving, and then adding the checkbox back on the blog.  The RSS channel is created, but I still get the error.
    This is the URL. (I'm on an iPad)
    http://reader.mac.com/mobile/v1/http%3A%2F%2Fwww.bluemountainbistro.co m%2FRSSRetrieve.aspx%3FID=18026%26Type=RSS20
    If I manually add all the posts, obviously they show up... But I don't want to have to do that all the time...
    May 12, 2012 10:37 AM   in reply to Neil Eisenberg
    Hi guys,
    I'm having our team look into this further.  It appears after enabling "syndicate rss" within blog the system creates a new feed but it never seems to want to update with the posts.
    I'll let you know once I'm able to find more details.
    -Sidney
    May 12, 2012 12:57 PM   in reply to Sidney Mitchell
    Thanks.  This site just went live and they want to do a big promotion asking everyone to subscribe to the blog.  Obviously, I'm trying to stall them.
    May 17, 2012 9:15 AM   in reply to Neil Eisenberg
    Furthermore this has been identified as a bug and will be corrected in our next release.
    BugID: 3192268
    Thanks for your patience.
    -Sidney
    Jul 7, 2012 6:22 AM   in reply to Sidney Mitchell
    Sidney
    I still have this problem with RSS. I posted a support request, Case #0183391077, where I received the less than satisfactory solution on manually moving blog posts from left to right.
    The RSS ID in the address bar is showing 11231 - this doesn't work
    The RSS ID in the admin area is 11474 and it works.
    I've tried unchecking and checking the syndicate this button, logged in and out to no avail.
    Here's a screencast of the problem
    http://www.screencast.com/t/k3yyjzlr3jJV
    I hoping this can be resolved.
    Fraser
    Jul 7, 2012 8:15 AM   in reply to FraserMcCulloch
    I reported this months ago and was told it was going to be fixed in the next release which it wasn't.
    Neil
    Neil Eisenberg
    Design Intervention Studio
    "The Art of the Web"
    19 Birch Lane
    Woodstock, NY 12498
    845-679-8052
    www.designinterventionstudio.com
    Jul 9, 2012 10:36 AM   in reply to Neil Eisenberg
    Hi guys,
    Some positive news as this appears fixed in our latest release last week.
    • Issue 3192268 - Updated the "Syndicate this Blog RSS" option tooltip from the Blog details page to specify that only new blog post will be added to the feed once the setting is activated
    Reference: http://www.businesscatalyst.com/_blog/BC_Blog/post/July_release_-_New_ admin_user_interface_updates_additional_customer_reports_and_bug_fixes /
    Hope this helps!
    -Sidney
    Jul 9, 2012 2:11 PM   in reply to Sidney Mitchell
    Okay, got help from online chat with a solution. If the blog ever loses its channel, like in this case the channel ID didn't match the Blog's ID. Instead of unselecting and reselecting the Syndicate this Blog box which only provides a temporary solution in my case, uncheck the Enable box and then SAVE. Then check the enable, then Save.
    This apparently restored the blog's original syndicated feed.
    Teejay
    Jul 10, 2012 4:38 AM   in reply to Joel Media Group
    Teejay
    Thanks for tip. Tried this over 12 hours ago and waited and it doesn't work.
    Before Teejay's suggestion
    Old ID = 11231
    New ID = 11474
    After Teejay's suggestion
    Blog ID = 13410
    Correct ID = 11474
    http://www.screencast.com/t/TJvcnOIg
    http://www.screencast.com/t/NfTGk2KJtPk
    This is support case
    Case #0183391077
    Jul 10, 2012 9:22 AM   in reply to FraserMcCulloch
    Hi Fraser,
    I've double checked your case and it appears resolved.
    "Thank you. Problem solved. Created new blog."
    Please let us know if you have any further issues by reopening the existing case.
    Kind regards,
    -Sidney
    Jul 10, 2012 1:36 PM   in reply to Sidney Mitchell
    Yes Sidney, case closed, problem solved. cheers all for your help.
    Jan 24, 2013 6:52 AM   in reply to Sidney Mitchell
    FYI, we have been having related problems with at least two sites that we have checked...
    It started with the rss feed only showing 15 posts at a time.  Per support we deleted the rss channels and re syndicated the blogs and then waited and the rss channels were never updated...
    Finally I went in and added all the blog posts to the rss channel manually and then all 350+ posts appeared... not sure if new ones will show up or not...
    Just wanted anyone reading to know about this workaround...
    Patrick Steil
    http://www.podiotools.com
