aneasytorememberid
Apache DirectoryIndex changes on install
May 9, 2012 2:58 PM
Tags: #install #apache #cf10 #directoryindex
I just installed the Zeus beta and I noticed that the DirectoryIndex in my Apache config look a bit off:
DirectoryIndex dex index.html index.cfm
Was there an extra "dex" added to that on install?
Amit
    May 15, 2012 12:21 PM   in reply to aneasytorememberid
    What do you find if you try the new final release? That came out just today/last night. If you still have the problem, do update your note here or better, report it as a bug. Hope that’s helpful.
    /charlie
    Jul 7, 2012 7:17 AM   in reply to Charlie Arehart
    Confirmed, I too have found this problem in the full release. I installed it on a fresh install of OS X Lion. It modified the httpd.conf file in the following ways:
    <IfModule dir_module>
    </IfModule>
    and later on
    <IfModule php5_module>
              AddType application/x-httpd-php .php
              AddType application/x-httpd-php-source .phps
    DirectoryIndex x index.html index.php index.cfm
              </IfModule>
    </IfModule>
    and of course at the end it adds
    Include "/private/etc/apache2/mod_jk.conf"
    This has caused issues with Apache not automatically opening index.cfm
    Please fix
    David
    Jul 7, 2012 7:35 AM   in reply to David Dykstra
    First: these are community forums, not an official Adobe supprt channel, so we can't fix things.  You would need to raise a bug with Adobe, and it'd possibly be fixed in the next update to CF.
    Secondly: if you selected the secure install option during installation... what you're seeing is by design.  Did you select the secure option?
    Adam
    Jul 7, 2012 7:38 AM   in reply to Adam Cameron.
    Sorry, I did report it as a bug also. No I did not select the secure install option.
    Jul 7, 2012 7:50 AM   in reply to David Dykstra
    Ah, well that sux then! What's the bug ref?  I'll go vote for it.
    Adam
    Jul 7, 2012 7:56 AM   in reply to Adam Cameron.
    Bug 3239392
    Jul 7, 2012 8:05 AM   in reply to David Dykstra
    Oddly enough after removing those seeming oddities it still didn't solve my problem. For some reason Apache won't automatically open the index.cfm file.
    Jul 7, 2012 8:22 AM   in reply to David Dykstra
    NVM, silly me. So the problem was the following
    </IfModule>
    should have been
         DirectoryIndex index.cfm index.html
    </IfModule>
    Looks as if the parser used to modify httpd.conf in the install is making some mistakes.
    and the x in the php module shouldn't be there at all.
    This solved the problem
    Please vote for the bug fix as it is simple to do
    David
