LR 4.1 latest ver.
I post process a CR2 file in Lightroom. I then add text to the Title field.
Export as jpg using a pre-defined export preset.
I then notice that I have a typo in the Title field.
Correct the typo / text in the CR2 parent file using Lightroom.
Re-export again (same export preset)... answering yes to overwrite file (and Yes to all metadata).
Surprise ...surprise... the Title data is not updated in the exported file (ie by viewing the metadata in the g or e view.
I delete the jpg
Export again ...yes... same preset export settings.
Metadata on jpg is correct.
So, it looks to me that Lightroom is not updating the metadata when exporting and overwriting an existing image.
Is this normal or a bug.
Looking forward to your comments / views.
I run into this all the time, and have for a few versions now. If you do a "Synchronize Folder..." after the latest export, the metadata will be updated in the library. The problem also shows up if you change the image size, crop, etc. Pretty silly error IMO...you would think LR could do its own housekeeping after all these years.
