When one rotates an image in a non-right angle in InDesign, the resulting image in the PDF, even if looks the same size of the original image when compared save for being rotated, actually shrink in size. That's noticieable when one saves the image from the PDF as the rotated image appears rotated inside the same size of the original, rather than being larger. I fear it may cause some quality loss at print. Is there any workaround around it?
Or it is just a previsualization glitch and the file prints normal? (as while importing the PDF in Illustrator seems to keep the original resolution of the image)
I can't see a difference in size between two copies of the same image when one is rotated in a non-right angle and the other is at zero rotation.
From the way your question is worded, I'm not sure what you are doing.
Peroyomas wrote:
…even if looks the same size…actually shrink in size.
If it looks the same size, what makes you think it is not?
