quicktime movie doesn't show up in shockwave
Jul 5, 2012 9:35 AM
Hi Guys,
perhaps somebody can help me with this question that is really hard to figure out.
I have a project made with director 11 that use some quick time videos(H264). Pubblishing the .app the project is ok. Instead if I export html and .dcr file, the .mov doesn't show up. I can hear audio, I can use interactive buttons, but the video is totally black.
To figure out I tried to put the URL in the internet button under the filename of the member tab. Also I tried to preload the movie using the following script but nothing.
Have you any ideas?
property pURLString -- the URL o  the asset to preload
property pNetMember -- the cast member to assign the URL to
-- Attach this behavior to a frame script or sprite.
-- This behavior preloads a user-specified URL string and
-- stores a reference to it in a global variable.
-- The status of the global variable needs to be checked with
-- netDone(_global.netID)to be sure the asset is loaded.
-- Ken Loge - http://dreamsteep.com
on getPropertyDescriptionList me
  list = [:]
  addProp list, #pURLString, [#comment: "URL of asset to preload:", #format: #string, #default: "http://dreamsteep.com/dreamedia/mov/Expand-Colors-1.mov"]
  addProp list, #pNetMember, [#comment: "Cast Member to assign the URL to:", #format: #member, #default: "Video1"]
  return list
end
on exitFrame me
  -- set the filename of the specified member to the specified URL
  member(pNetMember).fileName = pURLString
  _global.netID = preloadNetThing(pURLString)
end
___________
I am working on a IMac 3.4 Ghz Intel Core i7 8 GB RAM. Os X 10.6 snow leopard. Browser safari o google chrome.
Thank you very much,
Elisabetta
    Jul 7, 2012 8:43 PM   in reply to elisabettaclarius
    Are you running the DCR locally or off a website? If local, then you should put all files into a folder called 'dswmedia'. When running Shockwave with external material, a dswmedia folder is required for security reasons.
    If the file is running on the web, you could try link the video cast member to the URL.
    Dean
    Jul 9, 2012 7:27 PM   in reply to elisabettaclarius
    Elisabetta - have you tried the files on another computer?
    Is this with Director 11 or 11.5?
    It could be that the Xtra has not downloaded.
    - Go to Modify > Movie > Xtras
    - Click on the AQAsset
    - Make sure the Download if Needed is checked. Perhaps uncheck it and then reselect it.
    - Save and republish.
    Dean
    Jul 11, 2012 7:44 AM   in reply to elisabettaclarius
    Hi Elizabeth,
    I meant QT6Asset not AQAsset which was a typo. Reason it is it is QT6 is because that's the last version of the QT Xtra developed. If you want to contact me direct, maybe I can look at your video and see what's happening. My contact is d.utian@unsw.edu.au
    Dean
