Vertical gradient mask help
Jul 6, 2012 4:35 PM
I am trying to make a layer in a file appear gradually from bottom to top ( like a pile of sand grows as you pour on more sand ). What I mean by this is that I know I could use a transform tween but that is like a growing taller rather than a building gradually from the base. Does that make sense ?
I have tried everywhere and the tut's for grqadient masks are awful. Does anyone know where I can get a good tut on this ?
I want to do it without AS ! I am afraid giving AS to me is like giving whisky to the er, native americans; that's as PC as you're going to get...
TL.
    Jul 6, 2012 4:38 PM   in reply to Herugrim123
    Maybe you can use a rectangle with a gradient from alpha 0 to alpha 100 then animate this rectangle to create the effect
    Jul 6, 2012 5:02 PM   in reply to Herugrim123
    Here is a link to a file that demos how to do it with 2 movieclips and three lines of code.
    http://www,nedwebs.com/Flash/AS3_gradient_mask2.fla
    As far as taming gradients go, there is a gradient tool in the set of tools that you can use to modify the direction and other aspects of a gradient.  It shares space with the Free Transform Tool, so if you press down on that tool both should appear such that you can select the gradient tool.
    Jul 8, 2012 8:48 AM   in reply to Herugrim123
    I have a typo in that link... the comma should be a period.  I cannot tell what you have acquired from photoshop, but it might not be what you think it is - it could be a solid image regardless that you might not see part of it.
    You should resolve how to create the gradient in Flash and use that.
    Jul 8, 2012 10:37 AM   in reply to Herugrim123
    Yes, my file does not use a mask layer, it uses code to create the mask, much like your searching led you to already.  Your gradient should consist of a shape with either either a radial or linear gradient using the same color across it, but one end of it is set to an alpha value of 0.
    Jul 8, 2012 12:59 PM   in reply to Herugrim123
    If you are using a timeline mask, yes, you will get that hard line.
