Why are my DNG files so huge?
Jun 12, 2012 5:08 PM
My DNG files vary from about 46 Mb. to 66 Mb. I notice other people have much smaller files. Any ideas why? Can I reduce DNG file size?
    Jun 12, 2012 8:49 PM   in reply to grprt
    I don't convert to DNG very often. Most of the time I prefer working with the original raw files. So my observations may not be 100% accurate. The size of the DNG files can vary depending on the options you choose. For instance, including fast load data seems to add slightly to the size of the file. And, are you embedding the original raw file? That can affect the size of the file as well. So how are you setting up your options?
    Jun 13, 2012 12:26 PM   in reply to grprt
    Any chance you've fiddled with the "Custom" settings under Compatibility? If you turned on "Linear" or "Uncompressed" that could account for larger files.
    Jul 8, 2012 6:05 PM   in reply to Greg Barnett
    I have the same problem. Where do you change the "Linear" or "Uncompressed"? I am using Lightroom 4.1.
    Aug 18, 2012 10:34 AM   in reply to grprt
    Have downloaded the DNG codec several times as for some reason is slows my download time from sd card to a snails pace.One instance I timed downloading 32 12 mp files at 7 minutes which would make the time redicioulsly long.will download again and change the setting to 'embed origional raw files' and see if that helps
    Aug 19, 2012 2:27 AM   in reply to tackymar
    tackymar wrote:
    …downloaded the DNG codec…
    DNG "codec"?
