ELM2007
I get "invalid checksum" when opening "Photoshop_13_LS16.dmg"
Jul 6, 2012 8:40 PM
The installation is hung up.  What do I do now?
    Jul 7, 2012 10:55 AM   in reply to ELM2007
    You can go under Help>Contact Us and select your product.  You will then be given several options to choose from depending on your current difficulites.  There will also be links to the forums, chat support, and the relevant phone support for your region.
    As for the Invalid Checksum it sounds like Photoshop is still downloading.  Is this a purchased product or are you downloading the trial?  If it is a trial do you see any messages in the Adobe Download Assistant indicating it is either still downloading or extracting?  Also where did you choose to download your install files too, i.e. where are you double clicking to mount Photoshop_13_LS16.dmg?
    Jul 7, 2012 11:55 AM   in reply to ELM2007
    ELM2007 it sounds like the Adobe Download Assistant is having difficulties saving the install files to the location you have specified.  I would recommend completing solution 1 in Troubleshoot Adobe Download Assistant - http://helpx.adobe.com/creative-suite/kb/troubleshoot-download-assista nt.html#main_Solution_1.  When you reiniate the download I would recommend choosing the default location of your User folder to download the install files too.  Once the download is complete you can then install the software to your Applications folder.
    Alternately you can follow the steps listed in http://forums.adobe.com/thread/981369 to initiate a direct download.
    Jul 8, 2012 10:46 PM   in reply to ELM2007
    An invalid checksum is caused due to corruption in the downloaded file. It may be due to a spotty internet connection.
    If the download is completed in the Adobe Download Assistant you can temporarily turn off the feature to verify the checksum.  The following steps will allow you to temporarily disable this feature:
    1. Open the Disk Utility located in Applications/Utilities
    2. Go under the Disk Utility menu and select preferences
    3. Deselect the option to verify checksums
    4. Try mounting your DMG file
    I would recommend turning this feature back on though after the installation is complete.  Also if you notice this happening on additional files it can indicate a problem with your Internet connection.
    If the install is successful, remember to enable verify checksums.
