When there is a Smart Shape with both a stroke and a fill, plus a drop shadow, the drop shadow looks like it only applies to the stroke. I have several such objects with fairly thick 3 or 4 pt stroke. The drop shadow should be behind both the stroke and the fill. To avoid this I've been creating two identical shapes when only one is needed. The bottom shape has a drop shadow and the top shape does not.
Does anyone know a better workaround that doesn't require so many shapes?
Hi Jay,
As you are used to, I double-checked what was my idea about those shadows: being simply a slightly moved duplicate of the original shape with the color, alpha and other settings you setup in the PI, Shadow accordion. I published to HTML5 and everything showed up as expected, here is a screenshot of that published version:
For the first smart shape I only decremented the Alpha more for the Fill in order to see better the duplicate, shadow image. The second one has no fill, but I customized the shadow color.
Could you post a screenshot of your different result?
Lilybiri
