Vincent Choy
Flashbuilder 4.6 failed to start
Jul 9, 2012 2:07 AM
After splash screen, there is error message window show up to ask to check '.log' file. Below please find the details of log file.
Background:
OS: Windows 7 sp 1 (64 bits)
RAM: 4GB
!SESSION 2012-07-09 17:03:22.082 -----------------------------------------------
eclipse.buildId=I20100608-0911
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.resources 2 10035 2012-07-09 17:03:24.307
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.equinox.preferences 4 2 2012-07-09 17:03:26.294
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.equinox.preferences".
!STACK 0
java.lang.ExceptionInInitializerError
          at com.zend.php.ui.preferences.PreferenceKeys.b(PreferenceKeys.java)
          at com.zend.php.ui.preferences.PreferenceInitializer.initializeDefaultPr eferences(PreferenceInitializer.java)
          at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper $1.run(PreferenceServiceRegistryHelper.java:281)
          at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
          at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper .runInitializer(PreferenceServiceRegistryHelper.java:284)
          at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper .applyRuntimeDefaults(PreferenceServiceRegistryHelper.java:130)
          at org.eclipse.core.internal.preferences.PreferencesService.applyRuntime Defaults(PreferencesService.java:369)
          at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntime Defaults(DefaultPreferences.java:166)
          at org.eclipse.core.internal.preferences.DefaultPreferences.load(Default Preferences.java:237)
          at org.eclipse.core.internal.preferences.EclipsePreferences.create(Eclip sePreferences.java:307)
          at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode (EclipsePreferences.java:543)
          at org.eclipse.core.internal.preferences.EclipsePreferences.node(Eclipse Preferences.java:669)
          at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractS cope.java:38)
          at org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScop e.java:67)
          at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreference s(ScopedPreferenceStore.java:250)
          at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(S copedPreferenceStore.java:285)
          at org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet(ScopedPr eferenceStore.java:475)
          at org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean(ScopedPre ferenceStore.java:387)
          at com.zend.php.ui.ZendPhpUiPlugin.f(ZendPhpUiPlugin.java)
          at com.zend.php.ui.ZendPhpUiPlugin.d(ZendPhpUiPlugin.java)
          at com.zend.php.ui.ZendPhpUiPlugin$1.run(ZendPhpUiPlugin.java)
          at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
          at org.eclipse.swt.SWT.error(SWT.java:4083)
          at org.eclipse.swt.SWT.error(SWT.java:3998)
          at org.eclipse.swt.SWT.error(SWT.java:3969)
          at org.eclipse.swt.widgets.Display.error(Display.java:1249)
          at org.eclipse.swt.widgets.Display.checkDevice(Display.java:755)
          at org.eclipse.swt.widgets.Display.getSystemFont(Display.java:2412)
          at org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceC onverter.java:84)
          ... 22 more
!ENTRY org.eclipse.ui 2 0 2012-07-09 17:03:28.552
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2012-07-09 17:03:28.552
!MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter ', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.catego ry.help'
!ENTRY org.eclipse.osgi 4 0 2012-07-09 17:03:29.287
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.jface.preference.PreferenceConverter
          at org.eclipse.ui.internal.themes.ThemeElementHelper.installFont(ThemeEl ementHelper.java:103)
          at org.eclipse.ui.internal.themes.ThemeElementHelper.populateRegistry(Th emeElementHelper.java:59)
          at org.eclipse.ui.internal.Workbench$36.runWithException(Workbench.java: 1665)
          at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupT hreading.java:31)
          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.ja va:134)
          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2548)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja va:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:664)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashB uilderApplication.java:108)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:196)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:369)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
!ENTRY com.adobe.flexbuilder.editorcore 4 0 2012-07-09 17:03:29.638
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.editorcore.FlexBuilderEditorCore.stop() of bundle com.adobe.flexbuilder.editorcore.
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(Bundl eContextImpl.java:863)
          at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(Bundle Host.java:501)
          at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(Abstr actBundle.java:550)
          at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Fram ework.java:1097)
          at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(St artLevelManager.java:597)
          at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStart Level(StartLevelManager.java:257)
          at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(S tartLevelManager.java:215)
          at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend (InternalSystemBundle.java:266)
          at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework .java:690)
          at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.ja va:588)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStart er.java:415)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:198)
Caused by: org.eclipse.core.runtime.AssertionFailedException: null argument:
          at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:85)
          at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:73)
          at org.eclipse.core.internal.events.ResourceChangeListenerList.remove(Re sourceChangeListenerList.java:146)
          at org.eclipse.core.internal.events.NotificationManager.removeListener(N otificationManager.java:305)
          at org.eclipse.core.internal.resources.Workspace.removeResourceChangeLis tener(Workspace.java:1934)
          at com.adobe.flexbuilder.editorcore.editor.LiveErrorHighlightManager.sto pManager(LiveErrorHighlightManager.java:290)
          at com.adobe.flexbuilder.editorcore.FlexBuilderEditorCore.stop(FlexBuild erEditorCore.java:54)
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(Bund leContextImpl.java:843)
          at java.security.AccessController.doPrivileged(Native Method)
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(Bundl eContextImpl.java:836)
          ... 18 more
Root exception:
!ENTRY org.eclipse.dltk.core.index.sql 4 0 2012-07-09 17:03:30.079
!MESSAGE An exception has occurred while creating database factory
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.dltk.core.index.sql.h2" was unable to instantiate class "org.eclipse.dltk.internal.core.index.sql.h2.H2DbFactory".
          at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwExc eption(RegistryStrategyOSGI.java:194)
          at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createEx ecutableExtension(RegistryStrategyOSGI.java:186)
          at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutable Extension(ExtensionRegistry.java:904)
          at org.eclipse.core.internal.registry.ConfigurationElement.createExecuta bleExtension(ConfigurationElement.java:243)
          at org.eclipse.core.internal.registry.ConfigurationElementHandle.createE xecutableExtension(ConfigurationElementHandle.java:55)
          at org.eclipse.dltk.core.index.sql.DbFactory.getInstance(DbFactory.java: 54)
          at org.eclipse.dltk.internal.core.index.sql.SqlIndexer.<init>(SqlIndexer .java:53)
          at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
          at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
          at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
          at java.lang.reflect.Constructor.newInstance(Unknown Source)
          at java.lang.Class.newInstance0(Unknown Source)
          at java.lang.Class.newInstance(Unknown Source)
          at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createEx ecutableExtension(RegistryStrategyOSGI.java:184)
          at org.eclipse.dltk.internal.core.index2.IndexerManager.getIndexer(Index erManager.java:77)
          at org.eclipse.dltk.internal.core.index2.SourceModulesRequest.run(Source ModulesRequest.java:54)
          at org.eclipse.dltk.core.search.indexing.AbstractJob.execute(AbstractJob .java:76)
          at org.eclipse.dltk.internal.core.search.processing.JobManager.run(JobMa nager.java:467)
          at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
          at org.eclipse.dltk.internal.core.index.sql.h2.H2DbFactory.<init>(H2DbFa ctory.java:50)
          ... 20 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-07-09 17:03:30.081
!MESSAGE Plug-in "org.eclipse.dltk.core.index.sql.h2" was unable to instantiate class "org.eclipse.dltk.internal.core.index.sql.h2.H2DbFactory".
!STACK 0
