I just found that renaming presets use the "Original/Digitized Date Time", which could differ from the actual Date Time when camera battery deplished and the time got reset, or simply when having DST/Time Zone issues.
Is there a way to call the modified time?
I mean... IMHO this should be the default case!
I'm not completely sure what you are trying to achieve.
If you simply want to change the capture time for a bunch of images due to the reasons you mentioned, this will help you.:
http://help.adobe.com/en_US/lightroom/using/WS57264460-DC72-4a1f-A665- 1E90907A9FFD.html
You can use the RC File Renamer plugin, if you really want use another Date/Time instead of Capture Date/Time (Original) in your filenames.
But, most people would prefer to correct the capture date/time, if need be, then use it in the filename - thus the default.
Rob
I may have found the problem...
I thought the most recent date was the correct one. I then tried to change again the date/hour (set to October 31 2010) just to see what would happen.
Here is the new configuration:
The new Date Time has been put in "Date Time Original".
The second field is for the timestamp the camera was on when the I got the shot.
The "Date Time" field seems to be the creation date for the DNG file itself (maybe something changed that via a suboptimal copy process).
In the end... everything works fine, but those field labels are not that clear... are they?
