deeciple
Need help with hyperlinks in repeat region
Jul 9, 2012 10:56 AM
Hi All,
I don't know if this is the best way to do this but it's working, sort of.  I created a repeat region from a table row that displays master records from a recordset and made these into hyperlinks to link to the detail info for each master record.
I wanted to add the ability to sort the repeat region so I wrapped this in a spry data set.  My problem is that the sorting is not working properly.  When I click on a column header, the records are re-ordered but not properly.  I suspect that it is sorting on the code that creates my hyperlinks but that is just a guess.  I tried making the table row be the link but this prevents the data set from displaying any records.  I am stumped.  Any help is appreciated.  Here is the code for my repeat region and data set:
[CODE]
   <table width="100%" border="0" id="results">
     <tr align="left">
    <th scope="col">Airdate:</th>
    <th scope="col">Event type:</th>
    <th scope="col">Detail:</th>
    <th scope="col">Variance:</th>
     </tr>
      <?php do { ?>
        <tr>
      <td><a href="on-air-results-detailed.php?tblOnAirActivityID=<?php echo $row_rstOnAirActivity['tblOnAirActivityID']; ?>"><?php echo $row_rstOnAirActivity['Airdate']; ?></a></td>
      <td><a href="on-air-results-detailed.php?tblOnAirActivityID=<?php echo $row_rstOnAirActivity['tblOnAirActivityID']; ?>"><?php echo $row_rstOnAirActivity['DiscrepType']; ?></a></td>
      <td><a href="on-air-results-detailed.php?tblOnAirActivityID=<?php echo $row_rstOnAirActivity['tblOnAirActivityID']; ?>"><?php echo $row_rstOnAirActivity['DiscrepDetail']; ?></a></td>
      <td><a href="on-air-results-detailed.php?tblOnAirActivityID=<?php echo $row_rstOnAirActivity['tblOnAirActivityID']; ?>"><em><span id="AirAffected">
         <?php if (!(strcmp($row_rstOnAirActivity['OnAirVariance'],-1))) {echo "Air affected";} ?>
            </span></em></a></td>
    </tr>
    <?php } while ($row_rstOnAirActivity = mysql_fetch_assoc($rstOnAirActivity)); ?>
   </table>
   <div class="results" spry:region="ds1">
     <table width="100%" border="1" align="left">
    <tr>
      <th width="24%" align="left" spry:sort="Airdate:">Airdate:</th>
      <th width="25%" align="left" spry:sort="Event_type:">Event type:</th>
      <th width="23%" align="left" spry:sort="Detail:">Detail:</th>
      <th width="28%" align="center" spry:sort="Variance:">Air Affected:</th>
    </tr>
    <tr spry:repeat="ds1" spry:setrow="ds1" spry:odd="oddRow" spry:even="evenRow" spry:hover="hoverRow" spry:select="selectRow">
      <td>{Airdate:}</td>
      <td>{Event_type:}</td>
      <td>{Detail:}</td>
      <td align="center">{Variance:}</td>
    </tr>
     </table>
          </div>
[/CODE]
    Jul 9, 2012 11:05 AM   in reply to deeciple
    Please supply a link to your site.
    Gramps
    Jul 9, 2012 11:20 AM   in reply to deeciple
    In that case we shall start a guessing game.
    Q1. Have you set the column type to html?
    Gramps
    Jul 9, 2012 6:46 PM   in reply to deeciple
    Ken,
    I hope you realise that this is going to take a long while. I have got the time, but it's your project and the best way to get help in a case like this is to upload the site (to a temporary location) and supply a link to the site.
    In the meantime
    Q2. Did the column type declaration look like the following?
    ds1.setColumnType("Airdate:", "html");
    ds1.setColumnType("Event_type:", "html");
    ds1.setColumnType("Detail:", "html");
    Gramps
    Jul 10, 2012 12:13 AM   in reply to deeciple
    Please post the data table containing about 5 rows of data, i.e. no PHP scripts.
    Gramps
