vanna paavai
How do I get a photo inside a custom shape in CS6
Jul 9, 2012 10:12 AM
How do I get a photo inside a custom shape in CS6...
    Jul 9, 2012 11:42 AM   in reply to vanna paavai
    many ways.
    one method:
    make your custom shape.
    drag your image into that file (this should come in as a layer above your shape layer)
    go Layer>Create Clipping Mask.
    this will "clip" your image layer to the shape layer below.
    Jul 9, 2012 11:57 AM   in reply to vanna paavai
    You could also use the selection tools to make your custom shape (polygonal lasso etc). Make the shape on top of your image, then go to select > inverse; so you are selecting the pixels outside your shape. Then simply press delete. No you have your image in the shape you wanted!
  • PECourtejoie
    Jan 11, 2006
    Jul 9, 2012 1:07 PM   in reply to Sharon Huang
    Hi Sharon, your solution works, but I suggest to try Charles', the advantage of his method is that all pixels are still available, and it is possible to move the image or the custom shape independently, and the visible area will adapt accordingly.
    Jul 9, 2012 1:27 PM   in reply to PECourtejoie
    Also, in Sharon's method - "simply press delete" on a regular jpg picture will bring up the Fill Dialog in CS6, with Content Aware being default. Not what you you want here.
    If the OP wants to use a selection as a "custom shape", then creating a mask by clicking on the Add a Mask icon at the bottom of Layer panel (third in from left) is preferable to inverting the selection and deleting pixels.
  • Trevor.Dennis
    May 24, 2010
    Jul 9, 2012 3:36 PM   in reply to charles badland
    Or use the Shape to create a layer mask on the inserted image.  That way you can unlink the image and mask (the little chain icon between them) and fine tune the position, size etc.
    Jul 9, 2012 4:08 PM   in reply to Trevor.Dennis
    and that is probably the best way.
    See? Many ways...
