Hi Everyone,
I really need your help in converting from the ".prel" file to an mP4 file in Adobe Premier Elements 9. I am new to this program, so I learned how to edit the videos but don't know how to do this part.
How do I do this? When I open my project file, the "File>Export" button isn't highlighted for me to select it.
Thanks in advance for your help!
Jennifer
prel is the project file, not a video file
User Guide PDF http://help.adobe.com/en_US/premiereelements/using/index.html
Right click the PDF link in the upper right corner and select to save to your hard drive
-the page also has links to help pages for previous versions
Steve's Basic Training Tutorials http://forums.adobe.com/thread/537685
FAQ http://forums.adobe.com/community/premiere_elements/premiere_elements_ faq
TIPS http://forums.adobe.com/community/premiere_elements/premiere_elements_ tips
Neale and John T. have provided you with the answers, but for a little more background on the PREL (Project) file, see this ARTICLE.
Good luck,
Hunt
Jennifer,
That FLV output is because you chose Adobe Flash Media for the Export/Share settings. In the Settings Panel, there are scroll bars on the far-right, but they do not really stand out that well, and are often missed. To see all possibilities, just click+drag on the scroll bar, and more possibilities will be revealed to you.
Good luck,
Hunt
PS - As Neale points out, PrE is a "non-destructive" editor, so the original files are not changed in any way. As for the PREL, it has no media in it, and only links to Source Files, and instructions in XML code.
Hi Bill,
Thanks so much for the info! So, am I correct in assuming that I don't want to save as a FLV if I want to upload to something like YouTube?
Also, I can't seem to find the Settings Panel! Could you be more specific as to where to find it? And where the scroll bars are?
Sorry, this issue has really been a bugga-boo, not sure why it's been so difficult for me!
Thanks so much Bill!
Jennifer
FLV is certainly an option for YouTube.So is H.264 in an MP4 wrapper.
I normally Export to FLV, and have not noticed an issue with YouTube, but I am usually doing tutorials, or quick display material, so with my SD Project, it has worked fine.
Steve Grisetti has done the full Export/Share specs. for H.264, for YouTube in this FAQ Entry. Were I doing HD Projects, I would most likely use H.264.
For most Export/Share Settings, one will find them under the Advanced button. As for the scroll bars, look to the far right of the Share Tab's Panel. They are there, but not easy to see.
Good luck,
Hunt
Thanks Bill! I took a look at that FAQ that Steve created, but had a question about it. How would I find him to ask him? Also, how exact do each of those specs need to be? I feel like I'm operating on faith that it will come out right.
Also, this all seems so complicated to make an MP4, why is that?
Thanks so much for all your help! I appreciate it!
I'm on this forum pretty regularly, peanut. What's your question?
There's nothing wrong with operating on faith. That's what we all do. We find the best solution and then we share it with each other.
Those specs will give you the best possible quality on YouTube, based on the experience of a number of people. Is there a reason you'd prefer not to use those Share specs?
Thanks for the smile Steve, your response was cracking me up:)
You're right, there's nothing wrong with operating on faith:). There was no particular reason I didn't want to use those specs, I just have no idea what I'm doing or why I'm inputting those things, but I guess I don't need to know:)
I had a question about that FAQ sheet that you did. I didn't understand this last part:
1. From Premiere Elements, select the Share/Personal Computer option, then select the DV-AVI output option (either standard or widescreen).
2. Import this AVI file into Windows MovieMaker, place the file on MovieMaker's timeline and Publish (to your hard drive) a
WMV, dvd-quality (4:3 size) PAL 3,0 M.
Also, I don't have Windows MovieMaker, is that going to be a problem?
Jennifer
If you have Windows, you have Windows MovieMaker, which used to be a great program for converting files. But not since Vista, when Microsoft redesigned it as MovieMaker Live.
I'm not sure how else to say (1) though. Go to the Share tab, select Personal Computer (or Computer -- it depends on which version of the program you're using), then select the AVI option with the DV preset. Is that not an option you're seeing?
Hi Steve,
I will go back and check again on the AVI thing.
As for the Windows MovieMaker, I do have that, however, last time I tried to use it I encountered some problems. I will try again, but I'm wondering is this a necessary part of the conversion process?
Also, how long does the conversion process usually take?
Jennifer
Personally, I seldom use Windows Movie Maker (have the old, non-Live version), as I will just convert WMV material to another format/CODEC, to suit the needs. However, I use a shareware converter, DigitalMedia Converter 2.7 (older version from Deskshare), and it's not free.
I did use WMM recently, as I had 5 WMV's, that only needed a quick Trim and assembly into one WMV file. That was the first time in probably 6 mos. I also have issues with WMM, and it crashes often on computers that run PrE and PrPro with very large Projects, just fine.
Not sure if you need to use it, but it can be utilized as a conversion program, and especially for WMV materal. My older version will only Export to DV-AVI I, but that is close enough to work in PrE, or PrPro, in most cases.
Good luck,
Hunt
Windows Movie Maker 2.6 works just fine with XP, Vista and W7 32 & 64 bit. It retains the export to DV-AVI that was dropped from the Live version.
Cheers,
Neale
Insanity is hereditary, you get it from your children
Hi Bill, and everyone else on this thread:)
So, this is turning into a bit of a saga for me. I have now resolved the part of saving the files (converting them). The problem now is that they take so long to upload to Amazon S3 that sometimes it times out before I have finished uploading.
Does anyone have any suggestions as how I could resolve this problem? Is there any way to package the file or zip it up before uploading?
Thank you!
