Apply Colors From Scheme Sites
Jul 9, 2012 9:37 AM
Hey guys,
I am currently trying to create a pastelle color scheme for my Logo.
What is the fastest way to eye drop/save & apply colors to AI shapes, directly from color scheme sites on the web such as the following ones?:
http://colorschemedesigner.com/
http://www.colorschemer.com/online.html
Also, does anyone have any recommendations of other tools for creating great pastel color schemes?
Many thanks,
j
    Jul 9, 2012 9:54 AM   in reply to Josh525
    1. Swatches palette flyout > Open swath library > colro books > Pantone Pastel
    2. Window > color guide > choose a color harmony
    3. color guide flyout menu > save colors as swatches
    4. When done convert the first color from Pantone to cmyk or rgb depending on your usage.
    Have you tried using Adobe Kuler for generating color schemes? It can integrate directly with Illustrator. Here's a quick video tutorial.
    Jul 9, 2012 10:11 AM   in reply to Kendall Plant
    Colorschemedesigner.com will let you export an .aco file (from the menu > Export). Open that with Photoshop. Then save the swatches  as .ase from Photshop's swatch panel. Illustrator will open the .ase
    ColorSchemer.com has a desktop application which saves .ase files from that.
    Jul 9, 2012 1:24 PM   in reply to Josh525
    If you are using FireFox, you can install a plugin called "ColorZilla". Then you can grab any color palette straight out of a live web site and import it into Illustrator using a script I wrote:
    Fast way to import web colors
    -- but please note the final post in there. I have no idea why it would not work in some cases.
    Jul 9, 2012 1:30 PM   in reply to Josh525
    No worries for step 4, your printer will likely take care of this, or the cmyk to rgb converison will likely be good enough.
    IN this case you start out with a spot colro of PMS 0821 that would require an additional spot colro ink to print on press.
    Chaneg the valeus to belwo, and this will now print in the Cyan and Yellow channels
    Jul 11, 2012 5:43 PM   in reply to Josh525
    Josh,
    "eye dropping" is possible. This is the Mac way of doing it:
    Make sure both the Illiustrator window and the Browser window are visible next to each other.
    In Illustrator, select the Eyedropper tool.
    Hold down the Shift key and the mouse button and drag to a colour in the Browser window (it does not have to be a Browser window, it can be any other visible window on your screen).
    If you have an object selected in Illustrator, it will be filled with the colour when you release the mouse button.
    Ton
