Hello all, I am a fairly experienced web designer and have worked with a number of CMS systems before. However, I'm relatively new to using Business Catalyst and still trying to fill in the gaps by searching forums and whatnot.
I have added a Hostname (A Record) to my domain settings within the BC admin panel. To test it, I specified one of the already live pages as the start page. However, two hours later the subdomain cannot be found. The instructions were very simple and I followed them exactly. Is there some other reason why a subdomain wouldn't work?
Thank you,
Colin
Thanks for the fast response Mark. Yes I'm rather confused by this. I took a small screenshot of the line under my domain settings. The subdomain - http://mixes.newvybe.com/ has a 'Start Page' of /About, which is http://newvybe.com/about. However, nothing appears at that subdomain URL.
I will wait 24 hours to see if anything changes. If it's still not up then does anyone have suggestions of what I should do? There seems to be no cases of this occurring elsewhere online.
Hi there,
Your domain is not delegated to us and it has two A-records, none of which is pointing to us - http://www.dnswatch.info/dns/dnslookup?la=en&host=newvybe.com&type=A&s ubmit=Resolve
Your subdomain is neither an A-record nor CNAME - http://www.dnswatch.info/dns/dnslookup?la=en&host=mixes.newvybe.com&ty pe=A&submit=Resolve
You have two options:
- Create a CNAME or an A-record for mixes.newvybe.com and add it as a domain name to BC.
- Delegate newvybe.com to us and then create a CNAME for mixes.newvybe.com on your BC site.
Cheers,
-mario
Thanks Mario. I've been looking into this more. I'm newer to this group so still trying to figure out where all their tech stuff lies.
As far as your comment about creating specific type of records, no matter which option I click in the right-hand column (Create domain, CNAME, A-Record, etc.) the result ends up in the top Domain box. So even though I created the subdomain using the A-Record / Hostname option, it appears for me along with the domain. Is this because it isn't delegated to BC?
It appears as though there domain is being routed through CloudFlare since we are using one of their site speed optimization services. Is there anyway for us to administer a subdomain with BC without sending it to your nameservers?
Hey,
The About page seems to be working now - http://newvybe.com/about
If you want to have the DNS service hosted outside BC (to CloudFlare) you can skip the redelegation part and only create the subdomain like so:
http://helpx.adobe.com/business-catalyst/kb/domain-name-dns---quick.ht ml#id_42647
As your site is hosted on the US datacenter, in your external DNS service you will need to add the IP address 192.150.2.140
Matt,
The problem here is that your DNS is not hosted with us:
http://www.dnswatch.info/dns/dnslookup?la=en&host=quarsh.com&type=A&su bmit=Resolve
Which means that any record you create on your site will be created in our DNS, but it wont have any effect since your DNS is with ns.123-reg.co.uk
Cheers,
-m
Thanks Mario. I learn something every day! I did not set up the site so was not sure if the name had been transferred prior to me starting here. Would you recommend a transfer across to BC? They don't charge Im told but would be apprehensive about transferring a live site I could just buy the subdomains from 123-reg which should be straightforward enough but then how would I go about pointing an internal part of BC?
Matt
Hey Matt,
If you need subdomains you have two options:
- Leave DNS where it is create an A-record for blog.quarsh.com and point it to an IP address 192.150.8.140. Then in BC interface simply add that subdomain to the site as if you're adding an actual external domain name.
- The other option is to redelegate the domain to BC's DNS servers ns1.worldsecuresystems.com and ns2.worldsecuresystems.com and setup the subdomains in your site's admin.
Cheers,
-mario
