EULA reapears after streaming the disk to another machine with Citrix Provisioning Services
Jul 4, 2012 7:34 AM
We have a Citrix Xenapp 6.5 farm and we use Citrix provisioning services to stream 1 disk to multiple servers in the farm.
We use Adobe acrobat professional X and the EULA pop-ups keeps appearing for each user. During the installation of the master image the ACCEPT_EULA property is set to "yes"
The only way to get rid of these popups is to unistall acrobat and re-install it.
Is this the only way to fix this or is there a quicker method, script or registry entry or whatever to fix this issue?
    Jul 9, 2012 3:12 PM   in reply to Frenske1406
    How are you setting the property? Is it command line or via the Wizard?
    • If CMD, then get the Admin Guide and double check your syntax.
    • If Wizard, verify the property is set by inspecting the UI and the installer tables with the Direct Editor.
    Post back.
    Ben
