Hello,
Using javascript i am able to add some text to each page of an indesign file.
myNewText = "SOME TEXT"
myTextFrame = myPage.textFrames.item(0);
tempframe = myTextFrame.contents;
myTextFrame.contents = myNewText + tempframe ;
But i want to specify the font used,size and color for that text.
When i try the code mentioned in indesign javascript scripting guide
myNewText .appliedFont = app.fonts.item("Times New Roman");
myNewText .fontStyle = "Bold";
nothing gets changed and font family already used stays the same.
How can i do that only for the added text and not for the whole content?I dont want to add the text to a new text frame I want to append it to the existing text frame.
And is there a way to specify font size too?
thank you
There's a mixup going on here. Let's see if we can sort out some of it
at least.
If you just want to add new text to an already existing text frame,
that's easy:
myTextFrame.contents += "Hello";
But if you want the new text to have unique formatting, it's a little
more complicated.
There are two simple ways to do it, I think:
1. Create a temporary text frame, as you have done, and add the text,
and format everything in there. Then move() that formatted text to the
end of myTextFrame and delete the temporary frame:
tempFrame = app.activeDocument.textFrames.add();
tempFrame.contents = "New Text";
tempFrame.paragraphs[0].appliedFont = app.fonts.itemByName("Times New
Roman"); // etc...
tempFrame.paragraphs[0].move(myTextFrame.insertionPoints[-1],
LocationOptions.AFTER);
tempFrame.remove();
2. The other option, is to add the text directly to your textFrame. But
if you want to format only that text, you have to store where the text
started:
myTextFrame = app.selection[0];
firstInsertionPoint = myTextFrame.insertionPoints[-1].index;
myTextFrame.contents += "New Text";
myAddedText =
myTextFrame.characters.itemByRange(myTextFrame.insertionPoints[firstIn sertionPoint],
myTextFrame.insertionPoints[-1]);
myAddedText.appliedFont = app.fonts.itemByName("Trajan Pro"); // etc.
What you've done in your sample script, however, is to try to apply a
font to a simple JavaScript string. It won't work, but the way you did
it, it won't throw an error either, because in fact you've created a new
property of your string. (myString = "Hello"; myString.appliedFont =
"Times"; // myString now has a Javascript property called appliedFont --
but that's nothing to do with InDesign!)
HTH,
Ariel
