captainspin
Horizontal table anchor
Jul 8, 2012 7:20 PM
CS6: how can I anchor a rotated page with an inserted table to the introduction to the table which may end half way down the previous page?
So I have ended my table introduction half way down the page, then rotated the next page and created a table, then started the description of the table  at the top of the next vertical page. ( I know they are really all vertical). The rotated page with the table will not stay in the position following the table intro, even if I add sone returns and I don't like formatting that way. Nothing I can do will anchor the rotated table page to the text intro. I do not have this problem when I insert a table into a normal page of text.
    Jul 9, 2012 2:25 AM   in reply to captainspin
    Some pictures would really help here. Use the camera icon on the web page to embed an image in your post like this:
    Jul 9, 2012 3:50 PM   in reply to captainspin
    I'm not quite sure I understand what you are doing here, but I think rather than adding all those empty paragraphs you should either apply a keep option to the paragraph where the table is located that says start on nect page, or add a page break in place of the empty paragraphs.
    Jul 9, 2012 4:43 PM   in reply to captainspin
    If the table is the only thing in the paragraph, a keep option can be used to force it to the next page.
    Jul 9, 2012 4:59 PM   in reply to captainspin
    The table should be threaded right in to the flow of the text. At the end of the introductory material hit the enter key and add the table. Apply the keep option to that paragraph and the table will either go into overset, or move to the next page. On the next page (rotated) ad your text frame and make sure it is the next frame in the thread and your table should appear.
