Entering text
Jul 9, 2012 4:17 PM
Tags: #text
I'm currently running AI CS6.  In previous releases, when I wanted to start entering text at a certain point (with the regular type tool) I would position the I-beam at the vertical line where I wanted to start, and with the little horizonal line of the I-beam on the horizontal line where I wanted to start, and click.  But in CS6, that click seems to position the text on the left-most dotted line surrounding the I-beam, rather on the I-beam itself.  Is there some parameter I can set so that the I-beam determines the starting point of text?  Or do I just need to adjust my thinking to a different way?
    Jul 9, 2012 4:32 PM   in reply to Rodieck
    You might have Snap to Grid or Snap to Point on or Pixel Preview on. Look for these in the View menu.
    Jul 9, 2012 4:54 PM   in reply to Rodieck
    Rodieck,
    Just to be clear, when you mention that you "start entering text at a certain point" are you referring to using the type tool to a) edit an existing text field already populated with text, b) draw the bounding box for a new text field, or c) single-click on your artboard to create a text field.
    a)
    b)
    c)
    I really hope those pictures make sense, just trying to understand your issue fully.
    I don't have my second laptop with CS5.5 on it, but I see that the Type Tool in CS6 has the I-beam and then a small bounding box around it with a black triangle in the upper left corner. I looked in preferences to see if cursors could be adjusted and could not find anything myself. Someone else may know a way to do this, but I would suggest just getting comfortable with starting your text fields from the black triangle in the upper left corner of the Type tool.
    I hope this helps,
    Michael
