When I first heard that Adobe was going to put in paragraph and character styles in CS6 I thought, "Finally! Awesome!"
But, now that I have it and am using it I can't believe they have failed so hard in it. Every time I make a change in the style panel this little spinning dot wheel comes up and spins for at least a minute while think about making the change I made. This performance is unacceptable and needs to be addressed immediately. It even spins when I try to turn off the Preview checkbox.
I am using a Mac running 10.6.x and 8GB of memory. I have a lot of fonts installed, but that should NOT be an issue. It isn't with any other application.
Is there a way to speed things up?
I have the same problem. Win7 64bit.
Tested on the report:
i7, 8GB RAM, SSD 120GB, Nvidia GT 230 (desktop PC)
i5, 8GB RAM, SSD 120GB, AMD Radeon HD6490M (notebook)
It seems that the increase of 4 gigabytes of RAM to 8GB with a slightly accelerated, but it still takes a long time. The more styles or layers, it is slower. Indeed, it takes too long. It should come out some updates.
Translated in Google transtalor
Same story here. I love the feature in InDesign and was excited to see it ported to Photoshop as a timesaver for web mockups and other non-text-heavy projects. However it is NOT saving me ANY time. I am not sure but it seems the more places you have the style applied, the longer it takes.
I have a great machine running OSX 10.7.4 on a 1gb Radeon graphics card, 4ghz (8-virtual cores) CPU, and 12gb of RAM. I've got Photoshop working onto a separate scratch disc. This is very disappointing.
I guess I'll stop using it until they fix it.
Of course I am just running the trial version but it's supposed to run the same way isn't it?
By "a lot of fonts", how many? If more than a couple of hundred you might want to consider a font manager. Too many fonts will slow things down I read.
I have a font manager and also have close to a hundred fonts on my machine. My MBPro is as up to date as I can get it but still PS CS6 is so slow in responding to Type commands & Layer switch on/offs as well as other basic day to day commands that I have resorted to using CS5 again.
I don't see why CS6 should be so slow when the same process in CS5 takes half the time. Nothing has changed on my end - bar the CS6 update & Install.
Can't wait for an update to address this
Most likely you still have a corrupt font, OS font cache, or a problem with the font manager.
CS6 fixed a lot of issues with fonts, but we still find corrupt fonts that cause problems, and OS font caches constantly cause problems (especially on MacOS).
You might want to try the steps in this article: http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.h tml
I have many fonts. Default on to win 7 and 50 more so. According to Article http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.h tml I tried to check off and preview fonts and also to no avail. It still behaves the same way.
Yeah, I'm having the same issue. I do designs in photoshop and illustrator using the paragraph styles, it works just fine in illustrator but when I want to do the same in photoshop I can't make them nearly as fast or edit them as fast. A fix for this would be really nice I am going through the steps on the page Chris Cox left us but I'm pretty sure it's not going to fix this problem for me.
Either way hopefully something will happen witht his soon enough.
Chris,
Why would this behavior happen in Photoshop, but not in Illustrator, InDesign or Fireworks? Do they not use the same type engine?
Corrupt fonts should be buggy in all software, not just select apps.
I have Mac OS X 10.6.8 with 8GB memory. I am using Linotype FontExplorer X, but I have tried disabling this as well and jsut using FontBook (yuck!).
Also, FontExplorer X tells me what fonts are corrupt. There are other performance issues as well. For example, when thumbnail previews are turned on in the layers panel, Photoshop will"sit and spin" for several seconds when nudging layers because it is apparently redrawing the thumbnails constantly. It never did this pre-CS6.
I have to say I am disappointed and if these issues are not fixed I am probably going to cancel my supscription to Creative Cloud and go back to CS5. Right now the features that do work are not worth a monthly fee while we "hope" that they get fixed.
PS. I seriously wish Adobe would re-release ATM Deluxe for Mac OS X. Leave it just as it was for OS 9, just make it work in OS X. I bet everyone that uses a Mac for design would buy it.
Those applications share some code, but not everything, and we use the engines differently.
No, corrupt fonts can cause odd problems that may show up in one application and not another.
But right now we can't reproduce the slowdowns without corrupt fonts or corrupt OS font caches.
If there is another problem with the character and paragraph palettes - we need more details.
Yes, there is a known problem when moving several layers -- turn off the layer thumbnails for now to avoid that slowdown.
So I haven't finished going through my fonts just yet but I do believe you are right Chris, I have another machine to mess around on and it was having no problems with the paragraph / character style, it was working just fine. So I'm sure that it is a corrupt font that font book couldn't find when I validated all of them. I may just make a back up and slowly add them in until it breaks again or something. Either way I'll atleast give the font name so you can add it to the list of fonts that are known to cause problems with this.
I use Font Agent Pro v.4.2 and have not seen any slowness with Character/Paragraph Style Panels in CS6. (FAP has the ability to quarantine bad fonts.)
However, FAP 4.2's plug-in for InDesign will not work in CS6 and I have just been advised by Insider Software that a new Upgrade (FAP 5) is in the works but if I pre-order it, they will send the plug-ins which are part of their new version) for immediate use — and the new ones will work with Photoshop, InDesign and Illustrator CS6.
If you use FAP, it is essential to disable or remove any other font manager from your system.
Ok, I've tried all the solutions posted on the link you gave earlier Chris, but I haven't been able to resolve my problem.
I also tried CameraAnn's suggestion of Font Agent Pro to see if it could find any irregularities with any of my fonts. I actually ended up removing all of the fonts I installed that aren't system and I still cannot get this working correctly. I wasn't able to clear my OS font cache with the terminal code on the link, but I asked my coworker who is a bit more savvy with terminal than me and I ended up using this
"sudo su" *entered Password* then "atsutil databases -remove"
which spat out:
Removing: /private/var/folders/zz/zyxvpxvq6csfxvn_n00000c4000031/C/System
Removing: /private/var/folders/_v/gqnngbvj1xjf65_fb_jth23w0000gn/C/com.apple.Fo ntRegistry
I'm not sure what else I can do to try and get this fixed. If anyone has some other suggestions or something for me to try I'm willing to give it a shot.
I've also opened up another psd file I made a while back before I started using the paragraph styles and I exprienced the same problem when I was trying to make a new paragraph style.
I really like this feature its just painful to use at the speed its moving right now for my photoshop.
I'm going to try a few more things but I'm not sure it'll fix my problem. For now I have previews off for my paragraph styles so I can make changes to them within under a minute. I think it has some kind of rendering problem because when preview isn't on I can change this that and the other quickly. But when its on it gives me the spinning dots.
Also I'm wondering if there's a limit to how much it can handle?
We tested with tens of thousands of fonts, and complex documents. I don't think it's a simple numerical limit you're hitting.
I still think something is corrupt or interfering with normal operation somehow.
But to figure out the details, I need a system that shows the problem, or a reproduceable case.
Is there any way you can make a copy of a document that shows the problem available online? Even just a portion of one - for example just two layers - with which you can see the problem on your system. At the very least others can try what you're doing and report whether they see the same slowdown.
If it is reproducible with a document you provide, and it turns out to be something wrong in Photoshop itself that your particular document brings forth, Chris can get on with fixing the problem.
-Noel
Turning off the graphics processor setting did make mine go a little faster when changing a paragraph style, but it still was not as fast as Fireworks or Illustrator or InDesign. And I still got the spinning dot wheel for about 10 seconds when I changed a font setting from 13px to 20px where it was applied to 5 instances in the document.
My graphics card is an ATI Radeon HD 4850
I still do not think this is a font issue.
I have been experimenting with this, and I was able to reproduce some tremendous slowdowns (many seconds) as well, especially during manipulation of the Paragraph Styles dialogs while defining a style, using nothing more than a simple document with 5 text blocks containing Photoshop's Lorem Ipsum text and the Myriad Pro font. This is on a stable and fast PC workstation.
In fact, double-clicking a style in the Paragraph Styles panel brings up the Paragraph Style Options dialog right away, but just hitting the cancel button takes 4 or 5 seconds! I can reproduce this consistently.
Once defined, in a single 1400 x 1000 px document with 5 Text layers, I find it takes about 0.5 second to update the text of a paragraph to a style chosen from within the Paragraph Styles panel.
I don't know whether these things should be faster, but here's the document if it's helpful to anyone.
http://Noel.ProDigitalSoftware.com/ForumPosts/ParagraphStylesTestDocum ent.psd
-Noel
Noel, I tried your file on OS X 10.6.8.
With Type Layer(s) targeted, clicking on "Indents and Spacing" in the Paragraph Style Options dialogue results in about 10 seconds delay and a processor core being 100% utilised. There is no delay in opening other tabs of the dialogue. Clicking "Cancel" results in about 2 seconds delay.
It's even worse when no layer is targeted. The "Indents and Spacing" delay is greater than 20 seconds at 100% utilisation of a core.
Repeated several times with consistent result.
I tried styles to your PSD and there is a slight delay, but it's only 1-3 seconds.
But when I open the PSD with multiple layers of (web) and I want to change text styles, so the delay such as 20 seconds or more. And even if you only open the dialog box and press the styles cancellation delay is 10-20 seconds.
So it probably affects the number of layers.
Painfully slow here too - on Mountain Lion 16GB, as it was previously under Lion. Even Mountain Lion clean-install was fresh - i.e. had no fonts installed other than the defaults from a clean-install, i got the same issue.
I'm inclined to feel that until it's worked out what causes the problem, using the feature actually consumes more time to use than it saves.
A real shame given that it's intention is to speed workflow up not slow it down.
Rob.
Tired of waiting for Adobe to fix this issue (as well as other issues), which is clearly affecting many users besides myself. Probably many more users than even posted here. I have canceled my Creative Cloud membership.
CS6 has been out for 4 months now. It's not like Adobe hasn't had time to address the bugs. The features in CS6 are not worth the subscription price + the hassel of dealing with these bugs + my wasted time trying to use features that simply do not work as they should.
This is still not fixed in 13.0.1 and I can easily reproduce long delays, lockups, and crashes with simple style changes in the document I posted above.
Screen Grabs of Crash:
I had just changed the font size field to 13 pt
Windows Application Event Log Entry:
Faulting application name: Photoshop.exe, version: 13.0.1.0, time stamp: 0x5022da9d Faulting module name: MSVCR100.dll, version: 10.0.40219.1, time stamp: 0x4d5f034a Exception code: 0x40000015 Fault offset: 0x00000000000761c9 Faulting process id: 0x19a4 Faulting application start time: 0x01cd86aaad63c546 Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\MSVCR100.dll Report Id: 1212ddad-f2c1-11e1-b931-005056c00008
Last logged Photoshop CS6 Edit Log.txt entries:
http://Noel.ProDigitalSoftware.com/temp/Photoshop%20CS6%20Edit%20Log.t xt
There Were no new PSErrorLog.txt entries.
-Noel
I haven't gotten any crashes but I am still experiencing a super slow reaction when trying to use the paragraph styles. I really like the feature in illustrator when I do work in illustrator for web it saves me a ton of time but I can't use it on photoshop which is where I'm spending a lot of time in.
I hope the log you provided will be able to give them a clue as to why things aren't working correctly. Like ribrob said I've also gotten a new imac at work fresh install no fonts other than system fonts and it still acts this way.
For now I can't use the feature as it just sucks up time, but I'll keep an eye out for a possible fix or something.
So I recently had the idea of why not see if I can't just make a blank document and make my paragraph styles for my design and just save it then load it to the actual design. This worked, partially. I had to have at least some kind of text in my "blank" doc that had a paragraph style applied to it, which was no big deal to me really so long as I can just make all the stylings and just load them up and apply them to my designs. So after doing that work around I figured I had won! not really, now that I'm able to load my paragraph styles I have them all but they all changed the fonts that were set, all the color / size etc. were the same but the fonts all changed. This has pretty much defeated the purpose of the work around, I don't know if anyone is having a similar problem when loading paragraph styles or not but this is a problem.
I really want to be able to use this feature, and I'm trying to do some work arounds but its getting increasingly harder to even want to touch that aspect of photoshop :/
I hope you guys are looking into this I'm not sure what else I can do to get this feature to work but it would help my work flow a lot if I can use it.
Hello, same issue here, on a 27" iMac, Lion, 12GB ram, 1TB HD, AMD Radeon HD 6970M 2048 MB, 1300 fonts installed.
I’ve tested with the font test script for Photoshop you provide and detected NO issues.
My issues are:
More in general on PHP CS6 but not only
I really don’t get why we (the Professionals) should care about the interface color, while the speed is much more valuable; probably using a non standard UI uses huge amounts of CPU, without talking about the causal bugs you introduce, like the ones listed here.
Very bad, very sad ![]()
