I'm having trouble importing PowerPoint animations into Captivate 6. Some animations are running backwards. For instance, I have some fly-in animations that move from right to left in PowerPoint, but when I import them into Captivate 6 they run left to right. Not all animations do this, but at least one animation in every PowerPoint I've tried to import does have this problem.
Has anyone else experienced this or am I simply doing something wrong?
Dan
Hi Dan
Can you please send a test file having the problematic slide to rahuls@adobe.com<mailto:rahuls@adobe.com> . Also let me know if you are using the new “High Fidelity” option?.
Regards
Rahul
Hi Dan,
I tried replicating your scenario. But works fine for me.
Is the import done with High Fidelity checked?
Could you please share the cptx as well as PowerPoint file (pptx/ppt) with me so that we can figure out the problem.
You can send it to nitikuma@adobe.com
Thanks & Regards,
Nitin Kumar
Adobe Captivate Team
Hi there,
Could you please share the published output and the source pptx (only the slide having issue will also do) so that we can have investigate on it.
Also please let us know the PowerPoint version and Operating system you are using.
Thanks & Regards,
Nitin Kumar
Captivate Engineering Team
We are having the same looping issue with both PPTX 2007 and PPTX 2010. We did the High Fidelity import. And, the crazy part about the continuous loop is that not all animations are doing the loop. Only some of the animations, and it seems to be on the ones where we've delted and added it back in hopes of fixing the loop issue. Any thoughts?
