Noel Carboni 20,980 posts
Dec 23, 2006
Ps CS6 Color Sampler Cursor Hot Spot Inconsistent With Rest
Jul 9, 2012 7:17 AM
I don't use the Color Sampler Tool much, but In checking something for another thread, I noticed the cursor now seems inconsistent with the cursors of the other tools.
Basically, I expected it to drop the sampler on the little crosshair, and it dropped it instead at the end of the dropper.
This used to make sense, and it's still consistent with the Eyedropper cursor (and with prior versions of Photoshop).  But I find that now I've gotten used to the other new cursors, most of which now define the hot spot at the upper-left, it didn't do what was expected.
I guess there's not really a good solution for this, other than to just get used to it.
-Noel
    Jul 9, 2012 2:27 PM   in reply to Noel Carboni
    Seems like the icon is just a minor design flaw, although I presume they were aiming for consistency between the Color Sampler Tool and the Eyedropper Tool.
    A quick observation however: If you zoom into the maximum magnification with the Pixel Grid turned on, the entire tool (eyedropper + crosshair) fits into a single pixel. Since the tool seems to designed to select very precise areas of color, you would probably be sampling from either large areas of solid color, or zooming into a particular pixel.
    You make a valid point though!
    Jul 9, 2012 3:26 PM   in reply to Noel Carboni
    Or, use the Precise version of the cursor which is more, uh, precise...
    Jul 9, 2012 9:25 PM   in reply to Noel Carboni
    I think you'll find the same behavior in cs5 and even photoshop 7 is the same on windows.
    Jul 9, 2012 9:46 PM   in reply to Noel Carboni
    Okay, i see what you saying.
    That's what happens when one doesn't do a through read of a post.
  • PECourtejoie
    Jan 11, 2006
    Jul 10, 2012 1:17 AM   in reply to Noel Carboni
    Bonjour, Noel, Did you post this on the Feedback website? (with all the images?) you should.
  • JJMack
    Jan 9, 2006
    Jul 10, 2012 3:45 AM   in reply to Noel Carboni
    Does not Cap Lock give you the precise cursor.  Nole the eyedroppers hot spots have always been the tip of the dropper please let Adobe leave them there.  Yes Adobe did change some of the cursors hot spots in CS6 so one has to not adapt the those new added pointers the color sampler cursor icon symbol has not changed and there is little or no room to add and additional arrow pointer to it. Perhaps when we all have retina displays and Adobe get around to creating icons for its resolution Adobe can make larger icons and make room for the arrow pointer for you. Change is not always needed. Adobe eyedropper tools are consistent to the way one uses eyedroppers in every day life. Like the real McCoy virtual eyedroppers should not have external cross hair and arrow sites. You have precise cursors for when you want to take direct aim JJ::)
    In my opinion Adobe got it right in CS6 some things do work.  Don't give Adobe new thing to do leave them time to fix bugs anyway they are not doing to well now a days with new stuff.
