I have upgraded to Organizer 10. How can I import unique photos only?
Aug 1, 2012 3:40 AM
I recently upgrade from Elements 7 to Elements 10 and Premier 10.  Whn I brought my photos into Elements 10 a large number of files were duplicated.  And when I import photos from a camera it imports duplicate pictures if they exist on the card.  I spent many days fixing my catalog so that only unique images were in the folders as well as represented in the catalog.  It looks loke I will be facing the same problem again.  This is extremely frustrating.  I cannot determine what is causing this to occur.
    Jul 9, 2012 2:11 PM   in reply to MrBLB
    In Organizer, use Edit...Preferences...Camera or Card Reader and select the "Copy New Files Only" option at the bottom of the "Download Options" section.
    Ken
    Jul 9, 2012 11:55 PM   in reply to MrBLB
    Another suggestion to clean up the catalog from the last import batch(es):
    Instead of using Folder or Thumbnail view, use batch import view and select all the offending batches to delete from catalog and disk.
    Many photographers format their cards after each batch. Of course, it is prudent to do so only after your have done a backup of your catalog and picture files.
    Jul 13, 2012 3:49 PM   in reply to MrBLB
    Everything you send by email also appears in the forum here.
    Jul 13, 2012 11:53 PM   in reply to MrBLB
    I have no access for the moment to a Windows7 PC, but there might be a bug linked to the Windows version.
    In his faqs, John R Ellis states:
    "Many people have reported on the Adobe forums and Elements Village that PSE 5.0.2, 6, 7, and 8 run fine on 64-bit Windows 7 and Vista. The only known limitation is that the downloader will not start automatically, nor will it be listed in the Windows Autoplay options on PSE 7 and higher – you have to manually do File > Get Photos And Videos > From Camera or Card Reader:"
    This is only a guess. Maybe other users can check this behaviour ?
    Jul 14, 2012 12:16 AM   in reply to MrBLB
    MrBLB wrote:
    I the repeated the three photograph test and the were still
    imported each time (not being identified as duplicates).
    If you have Organizer apply any changes to the incoming images, such as fixing Red Eyes, or adding "Creator" or "Copyright" info to the metadata, then those saved modified images are not the same as the incoming images on the memory card.  Therefore, Organizer will not consider the incoming images as duplicates and they will be imported.  Their filenames will have a number appended so the filenames remain different.
    Ken
    Jul 27, 2012 7:24 PM   in reply to MrBLB
    MrBLB wrote:
    BUT, if I have photos/videos on the memory card and then
    shoot other photos/videos when I  do an import all the photos/videos, new
    and old, are imported.  The old photos/videos are renamed to have a '-1'
    appended to the end of the file name.
    Since we last corresponded, I've used the Photo Downloader a few times and discovered that the Preferences setting to "Copy New Files Only" is intended to apply only if the Download Option is set to "Automatic Download".  My Download Option is set to "Show Advanced Dialog", and when the dialog opens, all the images (old and new) on the SDHC card are selected (checked).  So, I learned that using the Advanced Dialog means that I first have to deselect all images, then select only the new ones before importing.
    Ken
    P.S., I did not test the "Automatic Download" option to see if "Only New Files" works, and it will be a few days before I can do that test.
    Message was edited by: photodrawken to add postscript.
    Jul 31, 2012 10:19 AM   in reply to MrBLB
    MrBLB wrote:
    To add to
    the confusion, if I import a batch with duplicates and then delete them
    using the catalog function, the duplicates are removed from the catalog
    view but the actual file is not deleted from the disk.
    This is working as designed -- as a safety precaution, the files on disk are not deleted unless you conciously choose that option in the confirmation dialog window.
    MrBLB wrote:
    I have scanned for any residual
    program files and have removed them.  At this point my machine should know
    nothing of the existence of Photoshop 10.
    Not really . See this Adobe document for the steps to manually uninstall PSE9, changing the folder names for PSE10:
    http://helpx.adobe.com/photoshop-elements/kb/manually-remove-photoshop -elements-9.html
    Uninstalling and re-installing is not going to solve your problem anyway....
    Ken
    Jul 31, 2012 3:14 PM   in reply to MrBLB
    Regarding the importing of "duplicate" files:  I found that any changes made to the files after they're on disk will cause them to be re-imported -- viewing in ACR and having the settings applied, etc.
    FWIW, I set the Photo Downloader to automatically import photos when the SDHC card is inserted, and then automatically delete the photos from the card after verifying the copying.  Plenty of confirmation dialogs during the process, and it works perfectly to prevent duplicates.
    Ken
