Can't rename file with modified date
Jul 9, 2012 3:46 AM
Tags: #lightroom #preset #time #date #rename #modified
I just found that renaming presets use the "Original/Digitized Date Time", which could differ from the actual Date Time when camera battery deplished and the time got reset, or simply when having DST/Time Zone issues.
Is there a way to call the modified time?
I mean... IMHO this should be the default case!
http://cl.ly/072X3A2g3M2w3H2o170T/Screenshot%20%202012-07-09%20at%2012.44.07.png
    Jul 9, 2012 7:06 AM   in reply to PaoloAvezzano
    I'm not completely sure what you are trying to achieve.
    If you simply want to change the capture time for a bunch of images due to the reasons you mentioned, this will help you.:
    http://help.adobe.com/en_US/lightroom/using/WS57264460-DC72-4a1f-A665- 1E90907A9FFD.html
    Jul 9, 2012 10:20 AM   in reply to PaoloAvezzano
    Paolo,
    LR works the way you want it to. When you modify the Date/Time, the Date/Time Original gets modified. That is the time that you told LR is the real time that the picture was taken. So the renamed pictures end up with the proper time embedded in the filename.
    Hal
    Jul 9, 2012 7:25 PM   in reply to PaoloAvezzano
    You can use the RC File Renamer plugin, if you really want use another Date/Time instead of Capture Date/Time (Original) in your filenames.
    But, most people would prefer to correct the capture date/time, if need be, then use it in the filename - thus the default.
    Rob
    Jul 9, 2012 11:31 PM   in reply to PaoloAvezzano
    Will the real "correct date/time" please stand up?
    Perhaps I don't read too good, but generally people want the capture date/time, which is the same as original date/time.
    I thought you wanted the "unqualified" date/time, which is more recent (09/04/12). Did I think wrong?
    Jul 10, 2012 3:25 AM   in reply to PaoloAvezzano
    I confess I'm still confused, but I'm glad you got it sorted out .
    Sorry for being dense ,
    Rob
