I've had some terrible crashing in InDesign CS6 (and Acrobat). At least 2-3 times per day. When InDesign crashes, I lose my preferences and some of my workspace settings. Any fix for this?
Any fix for the crashing? It's inconsistent on when it crashes (saving, exporting, etc) and I've re-loaded the entire suite again. I'm running OSX Lion...
Perhaps you are also being hit by this: http://forums.adobe.com/message/4548354
So I followed along with the disscussion on InDesign crashing. Seems most of the these were laptop and Air issues. One of the preference files helped me with my crashing issue.
However, every now & then I still crash because of my error. The problem is, regardless of why the program crashes, each time it does, I totally lose my preferences. My workspaces stay intact, however some of the palette settings go to deafult (fonts, colors, etc).
I have probably reset my preferences over 50 times since I've had the program and I'm ready to pull my hair out! Any solution for this?
You should try to figure out WHY your prefs keep going south. That's not normal.
And in the meantime, after you get things set up, make a bhackup copy of the prefs files and store it someplace safe so you can relaod them easily. See Replace Your Preferences
Hi Peter,
That's why I'm asking on this forum. I have no idea WHY this is happening with the prefs.
RE: Troubleshooting:
Hard Drive/Users/<USER>/Library/Caches/Adobe InDesign/<Version #>/<Language>
Stephanie
Most of the stuff that you are losing is stored in the InDesign Defaults file, not the SavedData file (that one saves the open recent list and the last state of a lot of stuff, but not the basic options you set in the prefs, or your document and print presets, which ARE saved in inDesign Defaults), so if that's the only one you can find, you'll at least get most things, and letting ID rewrite SavedData on close is not a big deal.
That said, I wish I could tell you why you aren't seeing any InDesign stuff in youtr cache, but I can't, and I'm a Windows user so not as up on Mac idiosyncracies as I probably should be.
And the next time you get a crash, please post it on pastebin.com and put a link to it here. Maybe we can figure out what the cause of the crash is.
With absolutely no information toi go on I'll go out on a limb and suggest it very well could be font related. It won't hurt to run a font utility to look for damaged fonts, nor will it hurt to clear the font caches. Do you run a font manager?
Although I have no answer as to why your ID keeps crashing, you can do this to restore your settings.
Frist try resetting your preference as you did by restarting ID, then set your preferences again, then quit ID.
Then go to the below directories and make a copy of the file "InDesign SavedData" and store it somewhere else.
Users/[user]/Library/Caches/Adobe InDesign/Version [version]/InDesign SavedData
If you happen to crash again and lose your settings, quit ID then replace the file in the above directory with your backup.
Hope that helps.
Message was edited by: j3n0
They will be in your MacHD/Users/<yourusername>/Library/ folder but with OS10.7, the user Library folder is now a hidden folder. See here
http://helpx.adobe.com/x-productkb/global/access-hidden-user-library-f iles.html
Peter -
Yes, I just followed the link now. I haven't had the issue wth the blank dialogue boxes, it just crashes. We'll see if this works.
Also, when I google show hidden files, I get the version of instructions with the "kill all". I tried this a while back & it didn't work. The link suggested by Larry above worked perfectly (thanks Larry).
Stephanie,
You need to go to the User Library, not the System, Library. To go there in Finder, press option then select "Go" menu, that will show the user Library folder and then you can to the respective folders.
For your crashing issue, always check for any updates by going to Indesign then from the Help > Updates
A couple of things. When I asked if you had tried the work-around for crashing above you said you weren't seeing blank dialogs, but I don't know if you actually downloaded and installed the files. I'm not sure you would notice the dialogs if you have the problem - they apparently flash by very fast before the crash.
It's possible, given the new error message, that you have some corrupt data in the recovery folder and ID is now in a vicious cycle of crashing when it tries to recover the bad file. The recovery folder is also hidden, but should be in the same place you found InDesign SavedData. Please rename it to _InDesign Recovery and see if ID will start.
After the crash on start-up, I reopened and so far it's working fine.
I did all the steps yesterday for the dialogue box crash, that's why I though maybe that caused something weird when I started up this morning...
So do I still need to do the _InDesign Recovery if the program's working so far?
I'm sure you can tell... but I'm NOT an IT person what-so-ever, so I just wanted to say thanks for all your patience in helping me. ![]()
j3n0 wrote:
Hope that helps.
I did this yesterday and following my crash this morning, I reloaded the data file - didn't work, had to reset all my prefs again.
Stephanie, I think I already mentioned that the Saved Data file is only one-half of the preferences set, and not the half that holds the things you keep resetting. Complete instructions are at Replace Your Preferences
What other programs, inconsequential as you might think they are, do you have open?
Do you have a font manager, or any other plugins from other vendors installed for ID? Constant crashing is far from the norm for CS6 and it almost always turns out to be some sort of system conflict on your computer if the procedures you've already tried are not working.
Here's the info I have Peter:
OS 10.7.4
Typical Open programs:
Yahoo Messenger
Safari
Outlook
iTunes
Stickies
InDesign
Illustrator
PhotoShop
Browse
Acrobat
AIM Chat
I've pretty much been using this array of programs all the time since I've had this computer (Dec 2011).
I have not downloaded or used any other plug-ins that I'm aware of.
No font manager besides fontbook.
It's not the crashing that bothers me... I've been a designer for over 20 years & I know that comes with the territory. It's having to re-import my color pallet and re-set all the preferences. The workspace stays the same, but the palette settings change. It's just one of those annoying things that I thought would have a quick fix. ![]()
Crashing in ID does not normally come with the territiory unless there is something wrong with a file. I don't think I see a crash in ID other than from a corupt file I'm testing more than once a year, if that.
I'm on Windows, so my experience is differnt from yours, but I'd try turning off Stickies, AIM chat, Yahoo Messenger, and iTunes to start. What is "browse" in that list?
You aren't running Hiss, are you? lots of other users reporting problems with it.
Well, I've stopped using some of my other programs (stickies, AIM, YM, and iTunes) when I have InDesign open and I really haven't had any crashes. I have, however had to force quit and when I do, I still lose my preferences. My default page size keeps changing to custom on it's own as well. I just try to keep up with things until a fix comes out... ![]()
