I use windows 7 and I have Cs3 and Cs5 on my computer. I keep trying to open up my InDesign files but they are not compatible with Cs3 which is the default opener. The files need opened up on Cs5 but the only way they will open is if you are in Cs5 version and go to open and browse to the file destination. When I right click on the file in the folder and try to do the open with it will let me browse but after selecting it does not add it to the program list or allow me to hit do this all the time. I've set up different files to only open up a certain program so I'm not sure why this one is so different. Any help would be greatly appreciated!
I mean why did you feel the need to create a new thread? All of the questions were answered in the other one:
http://forums.adobe.com/message/4546773#4546773
Bob
We told you in the other thread that if you want CS5 to be the default program you'll need to reinstall in chronological order.
Short of that you can attempt to hack the registry, and no I can't tell you the correct key, but some other users have posted about it here. Windows, by itself, will not honor an Open With request for an earlier version of an executable wioththe same name (in other words, both CS3 and CS5 have programs named InDesign.exe, and only the one in the registry, normally the last one installed, will get called). If you want files to open in the version from which they were saved -- a different problem-- you can prchase a utility from Rorohiko.com called Soxy that is supposed to handle that. Works well on Mac, but I don't recall any reports about Windows. The other option is to open the correct version, then use the File > Open... command and stop trying to double-click a file to open it.
If you uninstalled everything and reinstalled in order, CS3 should not be the default, so something isn't right about what you've told us. You may have to uninstall again, then run the clean tool (CS Cleaner Tool for installation problems | CCM, CS6, CS5.5, CS5, CS4, CS3) and reinstall again.
No update can fix a missing links warning. That means that the path stored in the file is no longer valid for the link. That happens when files are pased to a new user and the links aren't included, or if something gets moved.
ID's links are "absolute" in that they point to a specific location. If the program cannot find a link in the specified location it will attempt a search for any missing links starting inthe same folder where the .indd file was opened, and then in subfolders of that folder. It does not look higher in the directory structure, however. If you see a missing links warning that means that bot the absolute path and the search failed, and it's up to you to find the links.
Workspaces are stored in the user library or user profile in a folder called Workspaces. They are XML files and can be copied.
You can find where to look in this link: Replace Your Preferences
The workspaces folder should be a subfolder inthe same location you find InDesign Defaults.
Ok I found the xml file on the old PC and I copied it in the place that the current workspace is set up for the other PC. However I don't understand how it knows how to switch over to the workspace or how to access it. Do I need to copy paste and merge the two together? OR Use a different Setting? Or something else?
Oops I didn't see your other part. I did restart ID and I didn't copy any that said current. Does it make a difference if I am copying from XP to 7? I can see the workspace that's on it right now xml and I put them in the same folder so I would believe that's the right place. And that's what it said on the other link you gave me earlier.
On XP you should be copying from \Documents and Settings\<USER>\Application Data\Adobe\InDesign\<Version #>\<Language>\Workspaces and on the Windows 7 machine you should paste into \Users\<USER>\AppData\Roaming\Adobe\InDesign\<Version #>\<Language>\Workspaces
Make sure you get the correct folder locations. Workspaces are not dependent on the OS version, so that should not be a factor, and I've successfully copied from one version of ID to another as well when upgrading.
I know I copied them from that folder in XP. When I went to paste them into Windows 7 I got everthing up to \Users\<USER>\AppData\Roaming\Adobe\InDesign\5.0\ and then there was another xml file there that said somethingWorkspace so I just put them with the other one. I could give you an exact list of the folders it game me as an option but I didn't see any that said workspace and I did find an xml file already there that had the word workspace.
Verion 5.0 doesn't seem to use the \<Language>\ subfolder, so if there is no folder already named Workspaces, make one, so you have \Users\<User>\AppData\Roaming\Adobe\InDesign\Version 5.0\Workspaces and put the workspaces into that new folder. DON'T move the ActriveWorkspace.xml file that you found there previously.
Well I tried what you suggested and it didn't work. However if I back spaced and just put in \Users\<USER>\Appdata\Roaming\Adobe\InDesign there were two folders, version 5.0 and version 7.0 and we don't have a 7.0 version so I clicked on that one and it had a folder already called workspaces if you kept clicking so I put it there and it seems to have her workspace for the toolbars but the shortcuts didn't move over so I'm assuming she'll just have to set those up herself. Those folders were just the ones that came when they were installed I guess, but it seems like bad labeling to me.
OK, so now you might have a handle on version numbering. Take the CS# and add 2 to get the "real" version number. Your workspaces should be transferrable from CS3 to CS5, but keyboard shortcuts probably not. Unless there are tons of customizations it would be better to just make a new set, otherwise look on this forum for John Hawkinson's scripts for transferring keybaord shortcuts (I don't seem to have a link).
