Chapter Markers do not stick when encoding to H.264
Jul 10, 2012 8:21 AM
Tags: #will #not #chapter #h.264 #blue #in #to #pp #encore #encoding #setup #markers #when #stick #ray
Hello,
I like to use Encore chapter markers inside of PP, then when I export the media it already has them when the encoded media loads into Encore.
This always worked fine in CS5.5.
Now with CS6, the Encore chapter markers that I set in PP will not stick when encoding to Blue Ray h.264.  They do stick when encoding to DVD Mpeg2.
If I bring the DVD mpeg2 file into ENCORE, the chapter markers are there from PP.
If I bring in the Blue Ray h.264 file into ENCORE, the chapter markers have vanished, they are no longer there.
I have filed a bug report on this because CS5.5 didn't have this issue.
Just FYI...Encore charpter markers setup in PP will not stick if you export the media using Media Encoder, using the Blue Ray h.264 codec.
If you later take that encoded file into ENCORE, the chapter markers will n ot be there.
    Jul 10, 2012 9:30 AM   in reply to CAOLSEN
    I have been doing the same thing and don't notice this problem. For a test I just tried it both ways -- DL the sequence to an Encore Blu-ray project, and use AME to transcode the same sequence to H.264 Blu-ray (HD 1080i 29.97). In both cases the chapters show up the same in Encore.
    I'm on win7
    Jul 10, 2012 9:39 AM   in reply to Jerry Klaimon
    In Encore, are you using "Import as Timeline" and grabbing the video and audio together? If you just "Import as Asset" then you do not get markers.
    Jeff Pulera
    Safe Harbor Computers
    Jul 10, 2012 9:57 AM   in reply to CAOLSEN
    Behavior duplicated on my end - DVD works, Blu-ray does not, even though the .xmpses file is there in both cases.
    Jeff Pulera
    Jul 10, 2012 10:52 AM   in reply to SAFEHARBOR11
    I tried it a little differently
    Brought in the video as an asset, and then linked it to a button -- chapters still show up.
    Jul 10, 2012 11:06 AM   in reply to Jerry Klaimon
    I get Jeff's results. Chapters do not come in with H.264-Bluray (tried 23.976 and  29.97); no problem with MPEG2-Bluray.
    No difference exporting directly or through AME.
    Interesting; m2v sends them through the xmp file? m4v only uses xmpses?
    Jul 10, 2012 11:16 AM   in reply to Stan Jones
    No problem importing m4v asset with markers.
    Jul 10, 2012 12:07 PM   in reply to Stan Jones
    No, the .xmpses file has always contained the chapter info.  The .xmp file is for something else.
    I do get chapters with H.264 both when importing as an asset or as a timeline.
    Jul 10, 2012 12:51 PM   in reply to Ann Bens
    I'm on a laptop without the 6.0.1 update. Jeff, you have the update? Something is odd!
    Jul 10, 2012 1:06 PM   in reply to Stan Jones
    Workstation with 6.0.1 for both Premiere and Encore
    Jeff
    Jul 12, 2012 3:10 AM   in reply to Jim Simon
    Jim
    same here as Caolsen, encode as H264 Bluray, import as asset or timeline in encore >> no chapter markers
    export as Mpg2 DVD, import in Encore >> the chapter markers are there.
    from PP H264 footage to export to Encore, here my chapter markers show up.
    But I have 3 timelines sometimes four timelines that I want to export to the same Encore project, but each time it creates a new project.
    I had in the last 2 weeks four Bluray projects and each time I had to set my chapter markers anew in Encore, that is of course not convenient and wasn't a problem in CS5
    Maybe if you use to encode as H264 and not as H264 Bluray your markers show up?
    Martin
    Jul 12, 2012 3:39 AM   in reply to thanmartin
    I have just created a H264 Bluray file from a EX sequence with 11 chapter markers. When imported into Encore using 'import as timeline' I now have 12 chapters all in the wrong place. I have tried twice to create the file (7 hours each time) with the same results.
    Richard Knight
    Jul 12, 2012 6:12 AM   in reply to thanmartin
    Open the Encore project you want to add a sequence to. File -> Adobe Dynamic Link and select the same or a different PR project and the next sequence you want.
    Jul 12, 2012 6:15 AM   in reply to Richard M Knight
    There have been other reports on the Encore forum of odd results in importing chapters: random locations or too many or too few. I don't think the cause has been identified.
    Richard, you are always getting some kind of chapters?
    Jul 12, 2012 8:23 AM   in reply to thanmartin
    You guys are entering something in the Name field of the marker, yes?
    Nope, used the Blu-ray setting and it works fine.
    Jul 12, 2012 8:50 AM   in reply to CAOLSEN
    No.  I never have.  I am simply seperating music titles and their is no need to 'name' them.
    My clients just want the ability to skip to the next song.
    Well, name them and you and your clients will be happy!
    Jim, that is it. CS5? 5.5? we thought ended the need to do that, and the mpeg2 export makes it look like it shouldn't be necessary. But the h264bd export won't bring the markers in unless the encore marker is named.
    Help does not mention this, even though it does make the caution for flash cues.
    Jul 12, 2012 8:56 AM   in reply to Stan Jones
    I always name the markers and have not had any trouble with Bluray or DVD in CS5.5. The wrong chapter points I am getting in CS 6.01 are always in the same wrong place.
    RMK
    Jul 12, 2012 9:00 AM   in reply to Richard M Knight
    That's probably a separate issue, Richard.
    Jul 12, 2012 8:53 PM   in reply to Jim Simon
    Jim
    yesterday did a test, all encoded MP4 if you have chaptermarkers reimport with the chaptermarkers!
    That means encode HD as H264 >> your chaptermarkers show up if you reimport in PP and Encore
    Encode HD as H264 Bluray >> none of your chapter markers show up if you reimport in PP and Encore
    But just like Caolsen and probably many others I never named my chapter markers and I did not need it in CS5
    So I will try it out.
    But anybody knows why my markers show not up in the marker window. when I put them into a sequence.
    Before update 6.01 it showed.
    Mark a clip in source monitor.
    drag into sequence >> you see the clipmarkers and they do snap
    oben marker windows of sequence and you do not have any markers to go to.
    So what is the use of using source monitor to mark my clips, if I cannot jump or navigate to them in the timeline.
    So the only function seems to be: snap to
    However:
    create sequence, drag some clips, add timeline markers
    now add this sequence to a new sequence >> common workflow << or nested sequence
    You see the markers of the first sequence as clipmarkers >> but you cannot snap to
    Anybody has an idea and maybe this topic is discussed somewhere else
    thanks Martin
