Working with classes and accessing from the timeline...
Jul 10, 2012 10:40 AM
I am trying to externalize a class and am having problems getting my class to work. On the flash timeline, I have this function call:
CreateText(lessonTitle, "Headline_1", textWidth, textX, textY - 5, 0xFCAF17, 54, 1, true, 0);
Which calls out to an external class:
package {
    import flash.display.*;
    import flash.text.*;
    public class CreateTextBlock extends MovieClip
        public function CreateTextBlock()
                  // init
        public function CreateText(textString:String,
                                                  textName:String,
                                                  textWidth:Number,
                                                  textX:Number,
                                                  textY:Number,
                                                  textColor:int,
                                                  textSize:int,
                                                  fontStyle:int,
                                                  textWordWrap:Boolean,
                                                  myLeading:int):void
               trace(textString);
               trace(textName);
               trace(textWidth);
               trace(textX);
               trace(textY);
               trace(textColor);
               trace(textSize);
               trace(fontStyle);
               trace(textWordWrap);
               trace(myLeading);
My function call does not recognize CreateText(), but recognizes CreateTextBlock, however, if rename my CreateText function to ChangeTextBlock, I continually receive the error message:
1137: Incorrect number of arguments.  Expected no more than 1.
Can anyone help me refactor this to a working class?, or point out my flaw?, hopefully it's platently obvious.
Thanks so much,
Chipleh
    Jul 10, 2012 12:24 PM   in reply to Chipleh
    Do you create an instance of the CreateTextBlock class?  If so, you should be targeting that instance to call upon its CreateText method.
    Jul 10, 2012 1:11 PM   in reply to Chipleh
    Unfortunately I am anything but adept in class matters.
    If you used:
         addChild(TextCreator);
    to add the object, and that is the object you want to remove, then using:
        removeChild(TextCreator);
    should be all you need to do, and just after that assign it to be null to remove all traces of it and make it available for GC:
        TextCreator = null;
    Jul 10, 2012 5:50 PM   in reply to Chipleh
    You're welcome
