With the combination of tiny font size and the inability to set the contrast of the text and background, this batcave thing makes the interface text almost totally illegible on a glossy 27" monitor.
I am constantly having to use hardware zoom to make out the controls. Productivity is way, way down and eyestrain induced headaches are way, way up.
This shows a huge disconnect on the part of Adobe.
If every user was on a 17" non-reflective screen in a darkened environment and dressed like a ninja, I guess this would work. It sure doesn't work in the real world.
I can't wait a year for the penny to drop. I have work to do today - and a ton of it. A year ago, before the Helen Keller interface change with Adobe apps I could get things done. This is really silly.
For example, the photo lables in the library: text: 89% backbround: 77% - a difference of only 12%! Twelve percent?!
When you overlay this with a reflection of around 30% white, it is impossible to make things out.
I'm currently using an HP 2509m 25" 1920 x1080 display with a very glossy glass-like screen surface. I have the room lighting setup so that there aren't any overly bright lights near the display with no issues. You can increase the font in the side panels using Edit> Preferences> Interface> Fonts, but that won't change the grid view image fonts size or contrast ratio.
With a 30% glare on your screen you have bigger problems. There is no way you will be able to properly judge and set black points and shadow areas! Have you tried addressing this issue?
I don't know what "photo labels in the library" means exactly, but the text (filenames or whatever you have set up) is darker than the background on the Library mode thumbnails. For folder names, they are brighter than the background but it's RGB=216 versus 71 for the background.
Are you sure you don't have a corrupt monitor profile that's just messing up all the colors? Could you show us a screen-shot or, perhaps even better, a photograph of your screen?
I am in a brightly lit office environment, with reflects things like mad. No choice in environment. I calibrate weekly with DataColor. The issue is that Adobe decided to remove the ability to adjust the text and background of the interface. The concept of a miniascule difference in contrast between text and backgroiund of only 12% is nuts.
This display runs at 2560 x 1440. The nominal "larger" "smaller" type suze options are unrealistic considering the presence of super high resolution displays opn the market.
"the text (filenames or whatever you have set up) is darker than the background on the Library mode thumbnails"
Actually, the labels in the import window (see screen shot) are an average 63% on top of a background of 73%. . In the example below the words Add and Print Module have contrasts of approximately 67% & 79%) and are easy to read. The text in the dialogue box has a contrast of around 21% and is harder ro read. Just about everyting else is murky.
Here's another capture. Contrast between text and background is around 24%. 40% would be a lot better. Frankly, there is no practical reason for such a low contrast. There wouldn't be enough of an impact to affect vistual perception of the image you are editing. Remember, by the way, that the image here is a lot tougher to make out when using a high resolution monitor (2560 x 1440 in this case). That's about 110 ppi.
Wait - maybe it's because you don't have those thumbs selected.
All your screen shots are pretty decently visible to me, and I have a parapolic fluorescent fixture right above my monitor.
The resolution you are using isn't that high. I have a 15" laptop with a 1920x1200 monitor and the text is visible on that no problem. I also use Jeffrey's configurator to make the text smaller than you can make it with the regular controls.
ssprengel wrote:
The thumbnail text is dimmer when the image is unselected for Import. That is the difference between his and yours. Undo the checkmarks and compare.
The focus is intentionlly set on the "unimported" pictures, not those already in the LR catalog. Regardless, I can read the text on all of the pictures in the Import module with no issues. My display is ~89 dpi versus the OP's 110 dpi, which is about 25% smaller font size. My normal viewing distance is ~24" and even at 36" view distance (50% smaller font size) I can still read the Import text fine. Here's a 100% size screen shot:
Customizer2 double-click the below image to see full-size on your screen and see if you can read it. Make sure your browser is not windowed (i.e. set to full screen view).
So you didn't test Lr yourself before buying it, then?
You get 30 days' grace to see if Lr suits you, and I'd have thought that 30 seconds would be enough to show this problem up.
Yoiu can't honestly expect Adobe or any other software company to test for usability in what is by any definition, a really poor environment - where would that testing end? It's our responsibility to set up our working environments; and if that's a fait accompli, at least to test that the software is usable in the environment we're compelled to work in.
Can't you just sort out a monitor hood?
If you are using a 15" at 1920 x 1500, that would be about 162 ppi, making 12 pt text appear as 5.36 pt. That's tiny.
I'm dealing with two pair of 4' flourescents on a 90" ceiling. The issue is that Adobe has eliminated the ability to tweak the interface for less than ideal environments.
A side note: I've been using outboard calibration ever since my 21' PressView back in 1995. My calibration is in good shape.
BTW, thanks for everyone trying the lend a hand.
The labels on the selected photos are legible. the others are not as easy to see and the unselected options at the top of the window are very dark.
I spent years in a high volume workflow in the Chicago Loop. Speed is all-important and the abilty to instantly read the text is absolutely manditory. This ideal onscreen viewing environment is completely neutral in color and in value. The best with an environment of neutral gray and a black value of about 50%. Anything more than 10% either way throws off value perception.
This dark interface thing that has taken over Apple and Adobe is more about cool factor than practicality.
I believe Adobe has changed the LR4 UI for usage under optimum editing light conditions, which enhances the ability to adjust shadow details and black points. I agree that it is probably not necessary inside the Import module, but was probably done to maintain “balanced” screen brightness between modules. This helps to keep the pupils at the same dilation and reduces accommodation due to screen light level fluctuations.
I'd ask your boss if it would be OK to remove at least two (2) bulbs from the fixture. I had the same exact problem at my workplace and had the janitor remove three (3) of the 48" FL bulbs from the fixture over my desk. My neighboring coworkers saw the difference and then asked to have the janitor take two (2) bulbs out of the fixtures over their desks. My boss then came out of his office and asked for a vote, which was anonymous. He instructed the janitor to remove two bulbs from every fixture in the entire office space. He wasn't about to complain since he was paying for the electric bill.
If that doesn't work I'd take Keith_Reeder's tip concerning a monitor hood. I made one out of corrugated cardboard spayed with flat black paint on the inside and it did the job at a cost of 99 cents for the paint. You pays your money and takes your choice.
Adobe did not eliminate the ability to tweak the UI because that function was never in LR from the first public beta. Having a customizable UI color set might be nice but it would be a huge amount of work. Photoshop CS6 at version 13 at about 22 years old just got customizable UI colors (variable UI type was put in CS5 I think).
The root of your problem is your working environment...there are ISO standards you should check out ISO 3664:2009 Graphic technology and photography -- Viewing conditions. I think you'll find that trying to do digital imaging in your current situation sucks...and that's not Lightroom's fault.
You are right that it wasn't changed in LR. Adobe should be aware of the range of possible work environments and taken that into account. Such things have been standard with applications like Boris Red for a decade.. Coding color ssliders for background and type is not difficult.. Linking simply requies pointing at the value generated by the slider rather than a fixed value. The interface requires a bit of display text and a canned slider from their inhouse SDK.
The sad thing for me is having to move from Chicago to Hooterville (taking care of elderly parents). I'm still trying to convince the president that it's okay for the coffee machine to be on after 10:00 a.m. He can't get his head around this. Seriously. Things such as painting the walls and installing correct lighting is a bit more of a challenge.
I've recently(six months) started using a 27" display, and even though it's matte, it still picks up room reflections.
The two best--if not most convenient--things you can do is rig an approx. 4'x4' black card or cloth right behind you as you look at the screen, plus take all the ambient room light that's hitting you off of the side of you that faces the screen(black yourself out)..
One completely off the wall tip - you can use Jeffrey's Lightroom Configuration Manager to change the font to bold. It may help you a little http://regex.info/blog/2007-03-13/395
