PrePrint
Jul 10, 2012 11:15 AM
How would I script a prePrint event if I don't want a subform to print if the fields inside it are empty?
    Jul 10, 2012 12:02 PM   in reply to jeanette614
    to prevent user from printing you can use the validate element in the config DOM.
    Here's an article which descibes how to use it.
    http://forms.stefcameron.com/2008/04/13/prevent-printing-pdf-forms-in- acrobat-8/
    Jul 10, 2012 3:29 PM   in reply to jeanette614
    I use a function like the one below to test for a subform containing empty fields, so you could pass in the subform and if you get a true response set the presence property of the subform to "hidden".
    function isNull(node)
        //Debug.trace(arguments);
        var result = true;
        switch (node.className)
            case "exclGroup":
            case "field":
                result = node.isNull;
                break;
        for (var i=0; i<node.nodes.length && result; i++)
            var childNode = node.nodes.item(i);
            if (childNode.isContainer && childNode.className !== "draw" && childNode.className !== "variables")
                result = isNull(childNode);
        return result
    Depending on how complicated your subform is it might just be simplier to test the fields individually.
    Bruce
