If you put a block comment in front of a class declaration, autocomplete introduces a code-breaking semicolon
package {
* If there is any text here the autocomplete breaks
public class Product extends MovieClip {
private function doSomething() {
becomes
package {
public class Product extends MovieClip { ;
and
package {
becomes
package {
public class Product extends MovieClip;
but
package {
works just fine.
Am I missing something, or does Adobe not want us to comment our code? ![]()
Flash has an auto-formatting option if you are daring. But, be careful if you use auto-formatting. It can occasionally convert error-free code into problematic code. You can always use the undo command (edit > undo) to undo any problems caused by auto-formatting but, for the most part, I find it easier to maintain good formatting without using auto-format and risking the occasional problems.
When you use auto-format on code that contains more than 100 lines, it is easy to over-look an auto-format induced problem. So, if I have a block of 20 or 30 lines of code that need to be formatted in the midst of many more lines of code, I may open a new fla and paste the code in the Actions panel and use auto-format. If the code looks good, I will paste the formatted code over the unformatted code and then test to make sure no errors were introduced in the formatting process.
