cutarica.john
Script for Selecting Open Paths in Illustrator CS6
Jul 10, 2012 11:57 PM
I have created this script for selecting open paths in illustrator cs6 as the graffix plugin is not working under CS6.
Just save the following text in /Applications/Adobe Illustrator CS6/Presets/en_US/Scripts/Select Open Paths.js
if (documents.length > 0 && activeDocument.pathItems.length > 0){
          var allPaths = activeDocument.pathItems;
          var allPathsCount = allPaths.length;
          var openPathsAreLocked = false;
          var lockedOpenPaths = 0;
          var locked = false;
          for (var i=0; i < allPathsCount; i++){
                    allPaths[ i ].selected = false;
                    if( ! allPaths[ i ].closed){
                              try{
                                        allPaths[ i ].selected = true;
                              } catch (e) {
                                        openPathsAreLocked = true;
                                        lockedOpenPaths++;
          if (openPathsAreLocked) alert (lockedOpenPaths + " open paths are locked or hidden (or their layer is locked or hidden) and cannot be selected");
    Aug 3, 2012 8:12 AM   in reply to cutarica.john
    How do you do this on a mac? Or maybe I should say, what app should I use to create this? The Text Edit App won't let me save this  file. I can change the extension afterwords but no go.
    Aug 3, 2012 9:34 AM   in reply to TekART
    Copy the above and paste into the text editor of your choice. Force the text to plain text (not RTF; in TextEdit use as below). Save it as above.
    Aug 3, 2012 9:38 AM   in reply to Larry G. Schneider
    So it needs to be a txt extension, not js?
    Aug 3, 2012 9:53 AM   in reply to TekART
    Ah, got it. I opened the renamed file in the Javascript Console, pasted your file and renamed it to jsx. Then in the app, I found it under File>Scripts rather than Select>object where former plugins were located.
    Thank you.
