How do I restore the paragraph catalog to its original state?
Jul 9, 2012 7:20 AM
Tags: #paragraph_catalog #paragraph_tags
For a previous book, I deleted some tags from the out-of-the-box paragraph catalog. Now I don't have the full set of OOTB tags for use in a new book.
I do have an old document with all OOTB tags, and I can import those tags to the new book. But it would be a lot more convenient to simply go back to the original catalog. Is there a way to do this?
JP
    Jul 9, 2012 11:48 AM   in reply to doccojohn
    Open both the documents
    Goto File-->Import and select the one that you want to import from one doc to other.We have couple of options there.
    Harpreet
    Jul 9, 2012 2:34 PM   in reply to doccojohn
    If, by "out of the box," you're talking about the default tags that come
    with FrameMaker when you first install it, all you have to do is open a
    new, blank document and they will be there as the only tags. Then you
    can import them into any other documents you want.
    Or did you alter FrameMaker itself to change the values of these
    defaults? For example, if I recall correctly, you can edit the
    fminit\custom file and save it to make FM use defaults that you set.
    (Someone please correct me if I am remembering the wrong file for this.
    I wouldn't someone to mess something up.) So, if you did that, you need
    to restore the original version of the file.
    Jul 10, 2012 6:30 AM   in reply to doccojohn
    FrameMaker is requiring a template? Are you sure you are following the
    right steps? To open a new, blank document:
    1. Choose File> New> Document (or type Ctrl+N). The "New" dialog opens.
    2. Click on either the Portrait, Landscape, or Custom buttons at the top
    of the dialog box. This will create a new, blank document, with default
    ("out of the box") tags.
    3. Open the Paragraph Catalog. The following default paragraph formats
    should be listed:
         Body
         Bulleted
         CellBody
         CellHeading
         Footnote
         Heading1
         Heading2
         HeadingRunIn
         Indented
         Numbered
         Numbered1
         TableFootnote
         TableTitle
         Title
    You can then import these tags into any document or book:
    1. Open both the file you want to import from (the new, blank document)
    and the file you want to import to.
    2. Click in the file you want to import into. (Or, in a .book file,
    select as many files as you want to import into.)
    3. Choose File> Import> Formats. Select the document you want to import
    from in the "Import from Document" dropdown list, and deselect
    everything else but Paragraph Formats (if you want to import only
    paragraph formats).
    4. Click Import*
    5. That should do it. The default paragraph formats should now be added
    to your existing document.
    • Warning! If you have formats in your existing document with the same
    name, they will be overwritten with the properties of the imported
    formats bearing that same name in the blank document. So, if you
    customized those paragraph formats in your existing document, your
    customizations will be lost.
    My apologies if I'm telling you anything you already know. I have no
    idea if you are a new or experienced user.
    Deleting a paragraph format from the Paragraph Catalog permanently
    removes it from THAT document and ONLY that document. It affects no
    other document, existing or future.
    Jul 11, 2012 9:46 AM   in reply to doccojohn
