avidboy0`
timeline offline
Jul 10, 2012 3:49 AM
What does it mean when you open a project and some of your timelines are offline but the media that the timelines are associated with are fine? Thank you
    Jul 10, 2012 4:43 AM   in reply to avidboy0`
    External Drive or other situations where drive letters change? Permission issues? May need to "run as administrator."
    Jul 10, 2012 6:08 PM   in reply to avidboy0`
    Yes, it would.
    Two rules of thumb:
    a) don't do things to assets in use by Encore outside the program.
    b) when replacing an asset change the name.
    For example, you decide to edit part of the content. If you are using an all adobe content, use "edit original." If not, make the change, but when exporting from the source program, change the name. then, from within Encore, use "replace asset," and select the new asset.
    I think you can still do this. FYI, some programs (e.g. Premiere) may use "sidecar" or other files which use the source file's name. You can't always just rename the file and expect all to work. If that is not an issue, just change the name, reopen encore, the file will be offline. Use replace asset and go find it. (Not where I can check. I don't recall what options encore has to find a source file - rather than located a transcoded file.) but replace is the safer move.
    While drive letters are not an issue on a mac, there are issues regarding the use of external drives and also with permissions.
    Jul 11, 2012 5:14 AM   in reply to avidboy0`
    I think that's it. The original video will no longer be in the project after the replace. If you are asking if you can delete the exported file that is not in the project, that's always a judgment call!
    Let us know.
    Jul 11, 2012 8:38 AM   in reply to avidboy0`
    Generally no; you must adjust the length of the timeline (drag it).
