Acrobat Convert to PDF as a web service?
Jun 5, 2012 3:22 PM
Tags: #conversion #rtf
Currently we're in need of an automated conversion solution that we would be able to plug into our application and perform RTF -> PDF conversion. I understand there may be licensing issues we'll have to tackle but we can get to that when the time is right.
So the most reasonable idea i can think of for this was perhaps somewhere there would be a web service that we would be able to connect to with our application, and expect a pdf document in return.
Does such a web service exist? I've had trouble locating anything like this in the API or other documentation on this site.
Maybe i'm off the mark? Is there a better practice for performing this type of task?
Thanks for your help
Jeff Rasmussen
  • David Kastendick
    Apr 7, 2010
    Jun 6, 2012 11:23 AM   in reply to jrasm
    Hi Jeff,
    We don't currently have an API that hooks into the CreatePDF service.  I've added this as a topic in our Ideas section: http://forums.adobe.com/community/createpdf?view=idea
    -David
    Jul 11, 2012 2:32 PM   in reply to David Kastendick
    We also would like to use CreatePDF as a backend for our application. Although you do not provide a web service, we are interested in having the application use a virtual browser (PhantomJS) to login, upload a document, wait,  download the resulting pdf, then present the file to the user within our application. We've actually made a proof of concept that works with a free online converter.
    Who would I talk to about licensing for such use? So we would use a single login, but multiple users would benefit from the service.
    I just chatted with one of your reps who seemed to think it was fine for my app to use PhantomJS with the $9.99 subscription. I dug around and found the terms of use and it specifies that "Adobe makes the Services available to you only for your individual use (including personal use and business use that directly benefits you individually)" so it sounds like I would need a special license agreement.
    Ken
    Jul 11, 2012 4:03 PM   in reply to ken@rightintel.com
    Hi Ken,
    I am a product manager for the CreatePDF service.  We do not currently have a way for customers to programmatically access our hosted PDF converter, however this is something we are thinking about.
    Please feel free to contact me if you would like to set up a call to discuss your requirements further.
    Laura.
    Nov 14, 2012 7:58 AM   in reply to ken@rightintel.com
    Ken
    has this changed at all?
    thanks,
    Tylon Robinon
    Nov 14, 2012 8:22 AM   in reply to tylonrobinson
    I've talked with Adobe a few times now and they are not interested in a special licensing and payment agreement for using PhantomJS to access the standard CreatePDF web site.
    It also looks like a CreatePDF API is not on the horizon at all.
    Nov 14, 2012 9:51 AM   in reply to jrasm
    Currently we use the API with Acrobat.com to send files, convert them, and then pull them back down. Today we received an email indicating that Adobe will no longer support PDF creation from Acrobat.com, but will require migration to CreatePDF. Is there an API that will replace the one we are using, or do we need to look for a different solution to converting our documents to PDF by the end of the year?
    Nov 14, 2012 1:29 PM   in reply to Lopedia
    It may be worth mentioning Adobe LiveCycle PDF Generator, something you would buy and host yourself, which might meet the needs if that is appropriate.
    Nov 14, 2012 1:34 PM   in reply to Test Screen Name
    I remember 2 years even trying to get pricing information on this and it was like Adobe just didn't want to deal with the product. Had a difficult time even trying to track down a real person to follow up with. We do about 1500 documents a month for automated conversion.
    It's too bad - the Acrobat API service was so simple and easy to use.
    Nov 15, 2012 12:47 PM   in reply to jrasm
    Hi Jeff,
    I will reach out to you directly to understand all of your requirements around API access.
    Laura.
