Hi all, and so sorry to have to post again as my first post has never had any responses except the initial ones. I want to do all the work myself but just need some coaching on what might be wrong..my site is wwwDOTselfdefenseproshopDOTcom.
Again any help or coaching is greatly appreciated...thank you..Dan
The SpryMenuBar is contained within a div called sidebar1. The width of the sidebar has been set to 150px as in
.thrColFixHdr #sidebar1 {
float: left;
width: 150px;
background-color: #ebebeb;
background-image: none;
background-repeat: repeat;
background-attachment: scroll;
background-position: 0% 0%;
background-clip: border-box;
background-origin: padding-box;
background-size: auto auto;
padding-top: 15px;
padding-right: 15px;
padding-bottom: 15px;
padding-left: 15px;
Simply place the menubar outside of the sidebar.
Gramps
Hi, I located the menubar code like you said that was contained within the div called sidebar1, however sidebar1 is setup as a Repeat area so it shows on all web pages within the site. So when I placed the menubar outside of the sidebar1 code it worked but it then shifted the middle colum and right right sidebar2 content downward...so I did an undo.
Here is the code below that shows the repeat
<!-- TemplateBeginRepeat name="Left Navigation" -->
<div id="sidebar1">
<ul id="MenuBar1" class="MenuBarVertical">
<li><a class="MenuBarItemSubmenu" href="#">Item 1</a>
<ul>
<li><a href="#">Item 1.1</a></li>
<li><a href="#">Item 1.2</a></li>
<li><a href="#">Item 1.3</a></li>
</ul>
</li>
<li><a href="#">Item 2</a></li>
<li><a class="MenuBarItemSubmenu" href="#">Item 3</a>
<ul>
<li><a class="MenuBarItemSubmenu" href="#">Item 3.1</a>
<ul>
<li><a href="#">Item 3.1.1</a></li>
<li><a href="#">Item 3.1.2</a></li>
</ul>
</li>
<li><a href="#">Item 3.2</a></li>
<li><a href="#">Item 3.3</a></li>
</ul>
</li>
<li><a href="#">Item 4</a></li>
</ul>
<h1 align="center"><br />
</h1>
<h1 align="left"> </h1>
<ul>
<div align="center"></div>
</ul>
<p><br />
<br />
</p>
</div>
<!-- TemplateEndRepeat -->
Start by validating your code and fix the signficant errors in your menu code.
http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.selfdefen seproshop.com%2F
Code is very confused towards the bottom of Sidebar1 and you're missing a closing </li> tag.
<h1>, <p>, <div> and <br> tags don't belong in your list menus. So you can delete them in Code View.
</ul>
</h1>
<ul>
</ul>
<p><br />
<br />
</p>
</div>
Nancy O.
Hi Nancy,
Yes that did help me, but after I deleted those ones that you did a strikeout on I still checked and it still showed I had 16 errors to fix.
I think I might have messed up some code when I started playing around with my original site.
Would you be able to help me again after I restore my site? maybe that will get rid of some of those errors I am praying. I am willing to do all the work, I am just not that much of an expert
yet with some of this.
Kind regards,
Dan
Hi Nancy,
Ok I got rid of my old code on the server and put it back to the original code before I tried inserting the Spry Menu.
I see though that I still have the 16 errors:(
I am looking at the ones that are non alt ones.
So the first one is line 99, having to do with the 'Home' button, I can see that. And my only guess is that it might need to be in CSS instead?
I'm really sorry I am a rookie at some of this, but am willing to try if you can coach me along.
Open your Template.dwt file. Bad code in red, code changes in green.
On line 183 - 186 you have duplicate <h1> tags. Remove them.
<h1 align="left">
<h1 align="left"><a href="http://selfdefenseproshop.com/products.php?cat=53">Safety Kits</a> <br />
</h1>
</h1>
On line 198 - 200, you have some more duplicate <h1> tags. Remove them.
<h1 align="left">
<h1 align="left"><a href="http://selfdefenseproshop.com/products.php?cat=54">Diversion Safes</a></h1>
</h1>
On line 215, you have a duplicate <form> tag. Remove it.
<form method="post" action="mail.php">
Line 217, you have this:
<p><FONT style="BACKGROUND-COLOR: yellow">10 free informative reports on personal safety for women. Fill out your first name and email address and hit submit</FONT>. </p>
Which should be expressed like this:
<p style="background-color: #FF6">10 free informative reports on personal safety for women. Fill out your first name and email address and hit submit.</p>
Don't worry about the MMcode for your rollovers.
Nancy O.
The ALT attribute is required as you can see here http://www.w3schools.com/tags/tag_img.asp. If you have a look at the images used in the menu bar, you will see that you have used the ALT attribute albeit that they are empty.
Gramps
Thanks Gramps. I was able to fix those and now understand about the Alt and fixed those.
This is for Nancy. Hi Nancy, I was able to eliminate all the errors and am down now to just the last 3 which I think are
the MMcode ones you mentioned.
Now I think I am back to where I originally wanted, which was to remove the existing links in "Sidebar1" and insert a Horizontal Spry Menu which is where I ran into trouble. I can insert it but it will not open Horizontally.
When you have time can you help me with that? thanks so very much I really am appreciating your help.
lol, thanks. Actually I meant to say I wanted to insert a Vertical menu bar. This is where I was at the beginning. When I do per your instructions and insert the Menu on line 109, it messes the page up. All the columns get pushed downward but the menu works ok. But if I insert it within the Left Column Repeat Region the columns are not affected and it looks ok but the menu will not work vertically.
Inserted on line 109 but the other columns are pushed down
Inserted at the top of the Repeat Region - columns are now ok but the menu
bar will not work vertically, it only opens Horizontally.
Yes exactly. So here is what now happens after I insert it on line #111 which is where I want it but its now within the sidebar1 which is in a defined RepeatRegion. It is placed correctly but when you hover over the item you can see that it will not branch out vertically it goes downward instead.
Here is a picture.
1-how can I center the menu like I have circled in red in my mocked up picture below
In SpryMenuBarVertical.css, change the value of line 16 to auto as in
ul.MenuBarVertical
margin: auto;
padding: 0;
list-style-type: none;
font-size: 100%;
cursor: default;
width: 8em;
2-can I color up the text at all on a Spry menu like this? I tried but it didn't seem to take.
In the same CSS file, starting at line 81, change the highlighted values
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarVertical a
display: block;
cursor: pointer;
background-color: #EEE;
padding: 0.5em 0.75em;
color: #333;
text-decoration: none;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarVertical a:hover, ul.MenuBarVertical a:focus
background-color: #33C;
color: #FFF;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarVertical a.MenuBarItemHover, ul.MenuBarVertical a.MenuBarItemSubmenuHover, ul.MenuBarVertical a.MenuBarSubmenuVisible
color: #FFF;
Gramps
The CSS has been heavily commented to help with these issues. Have a look at the followiing
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, a fixed width box with no margin or padding */
ul.MenuBarVertical
margin: 0;
padding: 0;
font-size: 100%;
cursor: default;
width: 8em;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are same fixed width as parent */
ul.MenuBarVertical li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 8em;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarVertical ul
margin: -5% 0 0 95%;
padding: 0;
font-size: 100%;
position: absolute;
z-index: 1020;
cursor: default;
width: 8.2em;
left: -1000em;
top: 0;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarVertical ul.MenuBarSubmenuVisible
left: 0;
/* Menu item containers are same fixed width as parent */
ul.MenuBarVertical ul li
width: 8.2em;
The reason why the main menu items have a 0.2em width difference is because of the borders in the sub menu items.
Gramps
Are you having the problem as I am? While using IE8, click on the Boys Results button and rapidly move up and down with your cursor.
http://gerberanalytics.com/tennis/tennis_header_test.php
I called this error into Adobe Support today. They were not aware of it and they have not gotten back to me.
I'll contact them tomorrow to see if they have made any progress.
Scott
Have a look here and, after fixing the problems, start a new topic stating the remaining problem(s).
Gramps
You are not using the latest Spry files
The latest version of the Adobe Spry Framework is 1.6.1, this is the same version that ships with Dreamweaver CS4. If you use Dreamweaver CS3 (uses Spry 1.4), its wise to upgrade your files to the latest version. This can easily be done using the Spry Updater that can be found here.
Gramps
Hi Altruistic. I posted a question yesterday about why my drop-down menu won't work. Is there any chance you would have time to help me out? I'd really appreciate any help you can offer. I'm using Dreamweaver CS5.5 on a Windows (Vista) computer, and the web site is; http://www.cglcontracting.com/index.html. Thanks very much in advance for any help.
Sorry Im getting confused as to whom is talking to whom now with this other person in on this conversation....LOL sorry...
I did the update
Now when I try to do a preview in IE from DW I get this message in the screenshot. Otherwise after I uploaded again and try it in IE the menu still is not working...:(
