jpadamslux
maximum 30 minutes with HLS-VOD to iOS device
Jul 11, 2012 11:36 AM
Hi
I'm having a problem with Flash Media Streaming Server 4.5
When playing a movieclip which is longer than 30 minutes, it plays well if I stream it to a flash-client but when I use hls-vod to send it to an Apple device, the player says that the file is exactly 30 minutes long.
The license shouldn't be the problem since I could stream to 500 flash-clients at the same time a few weeks ago.
The OS is CentOS 5.5
Any ideas??
    Jul 11, 2012 10:41 PM   in reply to jpadamslux
    You need to check the license configuration for hls vod.
    Check if in your httpd.conf (apache configuration file), you have location tag for hls-vod, something like this
    <Location /hls-vod>
        HLSHttpStreamingEnabled true
        HLSMediaFileDuration 8000
        HttpStreamingContentPath "../webroot/vod"
        HLSFmsDirPath ".."
        Options -Indexes FollowSymLinks
    </Location>
    and there HLSFMSDirPath points to the FMS's licenses folder location.
    For example, if you have FMS licenses folder at C:\Program Files\Adobe\Flash Media Server 4.5\licenses
    Then HLSFMSDirPath must be set to "C:\Program Files\Adobe\Flash Media Server 4.5\" .. It may be relative path as it comes in default apache installation with FMS.
    Restart server after that..
