Saving a shape to file?
Jul 10, 2012 10:58 PM
Tags: #illustrator #mac
I have simply created a special ellipse in illustrator that I want to save to file and import to an iPhone application. I was wondering about the following:
1) How do I make the file so that just the ellipse appears, ie cut everything else out of the file, all the white space, so that there just exists space for the ellipse shape and the ellipse shape only.
2) What file format would be the best to save it to? Any particular settings / suggestions?
Sorry if this is simple, I am new to illustrator.
    Jul 11, 2012 12:48 AM   in reply to kissfrito@yahoo.com
    File > Save for Web and choose PNG24 for the format.
    Jul 11, 2012 1:14 AM   in reply to kissfrito@yahoo.com
    Artboard tool --> Fit to Object, then enable the Use Artboards option when exporting.
    Mylenium
    Jul 11, 2012 1:55 AM   in reply to kissfrito@yahoo.com
    kissfrito,
    Make sure to tick Transparency.
    You can only save rectangular areas to the raster formats, so they will correspond to the Bounding Box (hence the need to Use Preview Bounds if you have a stroke, to avoid cutting off the outer half of the stroke at the middle of the straight parts).
    Jul 11, 2012 2:12 AM   in reply to kissfrito@yahoo.com
    kissfrito,
    It is in the main Save for Web (& Devices) window where you choose the format.
    In this case, or others, you may also wish to tick Anti-Aliasing in the Image Size window.
    Jul 11, 2012 4:45 AM   in reply to kissfrito@yahoo.com
    Your'e going to need to post some screenshot to explain "white specs". If it's a vector image within illustrator there's really shouldn't be any "white specs" unless you are using something like a drop shadow or outer glow and have a matte color set in the Save For Web window.
    Jul 11, 2012 5:00 AM   in reply to kissfrito@yahoo.com
    kissfrito,
    I am referring to the Image Size window inside the Save for Web & Devices window, not the general preferences which govern how your artwork looks in Illy; you should retick Anti-Aliasing there.
    You may also select a suitable Matte colour in the Save for Web & Devices window, corresponding to the background colour.
    Jul 11, 2012 11:54 PM   in reply to kissfrito@yahoo.com
    kissfrito,
    What happens if you change the Matte to the grey background colour?
    And do the white specs grow when you zoom in?
    Jul 12, 2012 1:26 AM   in reply to kissfrito@yahoo.com
    kissfrito,
    I asked about the specs size to rule out any monitor issue.
    When you use the GIF format with transparency, you have to use the Matte colour to avoid the whities, because the pixels in question are filled with a mixture of the image colour and the Matte colour..
    But it should be unnecessary when you use the PNG format with transparency, because the transparency is what it says.
    Jul 12, 2012 1:43 AM   in reply to kissfrito@yahoo.com
    You are welcome, kissfrito.
